VGT Actuator always fails prealign and self calibration test - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
 1Likes
  • 1 Post By DMan1198
post #1 of 11 (permalink) Old 03-24-2016, 08:23 PM Thread Starter
I am using autoenginuity to to a prealign and self calibration on my 6.7 turbo vgt actuator. The very first time I did the prealign, it said successful and bolted back on the turbo. Went to do the self calibration and it failed. All data says to redo prealign. I try it and it always fails. I cannot get the actuator to pass prealign. I even took another actuator that I know is good off a buddy's truck and it does the same thing. It says it fails the prealign too. Anyone ever run into not being able to do the prealign?
dave01gt is offline
post #2 of 11 (permalink) Old 03-26-2016, 03:17 AM
N of 60's Avatar
I have had to do sort of a prealign with my VGTs. 2nd time, I alined right up with the garbage can and have never looked back.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #3 of 11 (permalink) Old 03-29-2016, 07:30 PM
7492's Avatar
Wish I could help. Are you satisfied with the Autoenginuity? I've been thinking of getting it.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
2020 KW T370 PX9 380HP 1250lbft @ 1400 RTO14908LL
7492 is offline
post #4 of 11 (permalink) Old 03-29-2016, 08:05 PM Thread Starter
It's crazy how many things and sensors it can read. It's way over my head on how to use everything. I just got it to help with some more simplistic issues that I may have. I would recommend it.
dave01gt is offline
post #5 of 11 (permalink) Old 03-29-2016, 09:01 PM
#40Fan's Avatar
Make sure the batteries are fully charged when running the test.
2011 2500 CC ST G56 LB MM 5" Flo-Pro 463
#40Fan is offline
post #6 of 11 (permalink) Old 03-29-2016, 09:27 PM Thread Starter
Batteries are good. I'm going to call Autoenginuity tomorrow and see if they can tell me anything.
dave01gt is offline
post #7 of 11 (permalink) Old 03-29-2016, 11:42 PM
FWIW
The grid heaters turning on can cause the voltage to drop substantially, even with good batteries. I have seen that interfere with communications between a tuner and the ECM when attempting to do updates.
2017, 3500 4x4 DRW CC 6.7 Aisin 3.73s, Aluminum Flatbed, CTS2, Luverne steps, Titan fuel tank, ATI Auxillary fuel tank & Airlift Wireless Bags
07Dually is offline
post #8 of 11 (permalink) Old 07-22-2019, 12:31 AM
I have The same issue I use the autel 906 scanner to try calibrate the actuador on my 2012 6.7 and just keep saying fail to pass
Ervint30 is offline
post #9 of 11 (permalink) Old 07-22-2019, 04:17 AM
N of 60's Avatar
A 3yr old post, I like it when people come here to get help and never return to share the fix.
I gave up on my Stock VGT after the second try of a clean and replacement. If your deleted, just get rid of it and go back to a simple old school spinner. IMHO and experience.
N of 60 is offline
post #10 of 11 (permalink) Old 07-22-2019, 12:30 PM
Ducati M.
DMan1198's Avatar
Generally if it passes the first part of the pre align, then fails to align when you put it on the turbo the collar probably isn’t in the right spot.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is offline
post #11 of 11 (permalink) Old 07-22-2019, 12:34 PM
Ducati M.
DMan1198's Avatar
I never had a problem with my vgt, but Iíve never regretted ditching it. Life is better with the big fixed vane.
N of 60 likes this.
DMan1198 is offline
