We have recently released the new automatic version of our popular 400P-RV portable compressor. It has over 60 ft. of reach and operates up to 150 PSI. Like all VIAIR compressors, it comes with a 1-year manufacturer defect warranty.
Description:
400PA-RV is the third in a series of VIAIR portable compressors with automatic shut-off function. This 33% duty cycle unit is capable of working pressures up to 150 PSI and can be operated for up to 40 minutes at a time before needing to be rested. It comes with a close-ended gas station-style air gun with onboard air pressure gauge for added convenience. While the unit was designed specifically for RV tires, it can be used for almost any tire-filling situation due to its included extension hoses (over 60 ft. of reach), and tire chucks. RV'ers will find the convenience of the 45-degree extended reach chuck perfect for dual wheel applications.
If you have any questions just let me know.
- Travis
