Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Upstate Diesel Performance
Upstate Diesel Performance Upstate Diesel Performance
Old 11-27-2008, 01:32 AM   #1 (permalink)
Posting Suspended
Adrenaline Custom Tunes Only Part 2
Ok since the last thread i started for this got so derailed by people not seeing what i was trying to do, i will explain a little better.
Post only your settings of the custom tuning and give a brief description of how it runs, and the manners of the performance of the tune, thats it!!!! Please keep the issues or problems in the Q&A thread.
Now this is in our own forum so i can delete all the BS if it starts again, not trying to be an AZZ but i started this for a reason that will come about at a later date and it will be helpful to all.
Diesel Dummy is offline
Old 11-27-2008, 01:37 AM   #2 (permalink)
Posting Suspended
thenatural31
....This is gonna be a great thread!
I have pulled this off another site. Quad has stated this information, so hope this helps a few of yall!!.......
Ok, I am going to give a rundown about how each tuning parameter works. I am going to do my best to explain this in plain english.
To start with, the test file I sent you is pretty mild but, can be made into the COMP file really easily. For the most part the actual fuel maps are the same across the board. Yes, there are a few different ones out there and when we actually go live with custom tuning we will also have more downloads that offer nothing more than map changes.
Pump Stretch.
This will make the biggest difference in overall power and smoke. This is the amount of time the injector is actually opened and spraying fuel into the cylinder. I have this set pretty low on the 1000 tune that I sent you. The COMP file is set to 1800. More than 1800 creates more torque and a lot more smoke but, actually makes less power on the upper end based on all the trucks I have had on the dyno. This is where the COMP file is set to. Feel free to run it to 2400 anytime you want lots of low end power and smoke but, realize you are giving power up on the top.
This does not mean you will get this amount of fuel all the time. There is a map, in percentages based off of this number as the maximum. Beyond that the map is also scaled by the TPS. So even if the map commands 100% but, you are at 50% throttle you will be getting 50% of the max stretch. If the map calls for 25% and you are at 50% TPS you will be getting 12.5% of the max stretch.
TPS MIN. For both CAN and Pump fueling.
This allows you to make the throttle lighter or more responsive. Basically it gives you a fudge factor that allows you to get a minimum amount of the max fuel stretch all the time. If you set this to 10% you will never get less than 10% of the fuel map. So if the map calls for 100% (1800) but, you are at 5% throttle you would normally get 5% of the map. If you set this parameter to 10% you will get 10% even though the mapping algorithm calls for 5%.
You have to be somewhat careful with this or you will be fueling way too much at light throttle. This is set to 0% on the tune I sent out.
TPS MAX. Both CAN and Pump Stretch.
This allows you to determine what throttle position you will see max fueling at. It also re-scales the entire map based on what you select. This is set to 100% on tunes I sent out. This means that you will not get 100% of the map unless you are at 100% TPS. If you set this at 80% TPS that means you will get 100% of the fueling at 80% TPS. It also means that 80%=100% and the map is scaled between 0% and 80% but, on a 0-100 scale. In other words the map moves in increments of .8% instead of 1%.
This can be really useful for those that drive light but, want power on tap earlier in the pedal but, not necessarily right off idle.
Timing MAX
Sort of goes without saying. 0 means we do not add any timing. 10deg means if the map calls for 100% you will get 10deg added over stock.
I never go over 7.5%. In my opinion that is more than plenty. If you are going for only mileage and are going to be easy you can use 10 deg and it should be great for mileage. The problem is that under much boost it could easily cause headgasket damage.
Boost Scaling.
This function is more of a smoothing function of the map. There are 20 positions that this function controls. Think of it at columns. Until boost equals a certain amount, then it is in a certain column. It takes more or less boost to move to different columns.
So if you set this to 20, then each column is changed by 1psi. If you scale it to 40psi then every 2psi it changes.
While this can make things more or less responsive or smooth it out slightly it does not make huge differences because not necessarily every column is more or less aggressive than the next. There have been maps in the past and there will be maps in the future where they will be more boost reliant. For now we do not rely on boost that much other than as this scaling function.
Hope that helps. If you have questions please let me know.
To turn your custom tune I sent you via email into a COMP tune follow these guidelines:
Timing = 7
Fuel Stretch = 1800
TPS MIN = 0 (both can and pump_
TPS MAX CAN = 100
TPS MAX Pump = 70
Boost Scaling = 25
Wholaa, COMP tune................
Enjoy...yall!...
Old 11-27-2008, 01:43 AM   #3 (permalink)
02 CUMMINS
snackpack's Avatar
Timing = 7.5
Fuel Stretch = 2000
TPS MIN = 20 (both can and pump)
TPS MAX CAN = 70
TPS MAX Pump = 70
Boost Scaling = 35
on the comp2 made my truck die, but smoked like mad, and was very strong
Timing = 7
Fuel Stretch = 1850
TPS MIN = 15 (both can and pump)
TPS MAX CAN = 80
TPS MAX Pump = 80
Boost Scaling = 28
again on the comp2 runs sweet. but i havent ran it turned all the way up yet
edit- i need to go see what the timing scale is. 23
02 silver QC, LB, 6-spd,ADRENALINE /PULSE , SMARTY, 150's, ARP studs, AIRDOG 150, Southbend DD, boost elbow, dual 4" silverline with 6" tips, S&B CAI Exhaust Brake
snackpack is offline
Old 11-27-2008, 05:27 PM   #4 (permalink)
02 CUMMINS
snackpack's Avatar
i ran this one, and i like it, again with the comp2 prog.
Timing = 7.5
timing scale 23
Fuel Stretch = 1900
TPS MAX CAN = 70
TPS MAX Pump = 70
Boost Scaling = 22
Old 11-27-2008, 08:21 PM   #5 (permalink)
99cummingetsome's Avatar
can qzilla or someone else post some custom tuning parameters for a mound of smoke? I am currently running the comp tune with the parameters set as follows:
timing 7%
both pump max's 100%
both mins' 0%
pump stretch 2000 or 2200 cant remember
timing scale 100%
boost scale 25
I like how the truck runs but i would also like to be able to save a tune just for smoke, and lots of it. I am currently running the comp tune that was loaded on the site 10/21/08 and haven't had any more issues with the truck dying with any of my custom tunes, so i will probably stick with the tune that is in it, but i have lost a pretty good amount of smoke even with the custom tuning. Can someone post up a tune with heavy smoke please?
99 2500 4X4 QuadCab Shortbed w/7inch BlackStack
Fuel By: Coaltrain Diesel, Quadzilla Andrenaline, and FASS
Clutch By: Valair Air By: Super B Special (coming soon)
99cummingetsome is offline
Old 11-29-2008, 07:14 AM   #6 (permalink)
Posting Suspended
Now this is for the tunes only keep the questions to the q&A thread please!!!!!!!!!!
Old 11-29-2008, 09:10 AM   #7 (permalink)
Go for Broke
Graphic Man's Avatar
good info DD :thumbsup
08 Mega cab is on it's way
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline
Old 11-29-2008, 11:57 AM   #8 (permalink)
Posting Suspended
Originally Posted by kooimanj View Post
Looking for a good towing tune. Any Ideas?
Ok im trying to be a d!ck but please read the title of the post and the very first post i put up,
this is for tunes only
DD
Old 12-09-2008, 12:00 AM   #9 (permalink)
ok guys lets get this thing bumped up i need some tunes to try!!!
Old 12-20-2008, 06:17 PM   #10 (permalink)
02 CUMMINS
snackpack's Avatar
this has died. is anyone havin luck with anything different? DD feel free to delete this, just wanted a bump
Old 12-26-2008, 01:45 AM   #11 (permalink)
mopartechnician's Avatar
Diesel dummy, don't yell at me just bumping this, by the way thanks for the christmas card, can't wait to order my adr/pulse. ONCE AGAIN DON'T YELL AT ME
mopartechnician is offline
