Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Upstate Diesel Performance
Upstate Diesel Performance Upstate Diesel Performance
Old 07-07-2009, 09:48 PM   #85 (permalink)
The header is a cool design and it is pretty well made. The fit and finish on it sucks. Who in there right mind welds a header together with what looks like 6011? Then leave the slag and spatter on it and spray it with some kind of gray stuff that is going to bake off the first time you heat it up. After several hours of work in the shop I made it look like something and now it is coated with something that won't come off with the heat of a taco fart. If any of you are still interested in seing this header installed I will have pics soon enough. I can tell you that the problem with the header was that it was made for something with a stock compressor housing. That problem was fixed but now it is no longer an equal length header. I have the header pictured in this thread and will be putting it on to see what it's all about. Jimmy and Chad had a chance to offer up something that could have been good for everyone, but it didn't work out. They could have told all of you that the results were great and get your orders in will they can still get them. They didn't do that. I wish it would have worked out for them. Maby I'll spend some time in the shop and build one they can sell. Till then, you will have to get yours from the guy that build his out of schd 40 black iron and uses 1/2" plates to hold the turbo.
Phil
1994 12 Valve Reg Cab Long Box (under construction)
2003 Duramax Reg Cab Long Box (bone stock)
Samdweezel05 is offline
The Following User Says Thank You to Samdweezel05 For This Useful Post:
GmcLbz (07-08-2009)
