| Upstate Diesel Performance Upstate Diesel Performance |
#25 (permalink) |
Lower Slower Delaware
Oh ok, so they can accomodate for compound setups. SWEET!!!! Im just running the A5K now butwill be running a compound set up next year. Thanks for the info DD.
'96' 3500 4x4 12 valve Aurora 5K Turbo Heavy Pumpin P-Pump KDP Tabbed FASS BHAF Banks Twin Ram 6" Bull Haulers and a few aces in the hole NO FARMS NO FOOD I.U.O.E. Local 542 "America is shaped by heavy equipment" |
#26 (permalink) | |
New England Chapter President
i just like droolin over pics :thumbsup
'01 - 2500 53 Block - 5 Speed
Catch me if you can. |
#28 (permalink) |
Cummins Crazy
![]() Join Date: Jun 2007
That is a wild header
My truck: 06 5.9 G56 4x4 Quad Cab Short Bed Patriot Blue. Smarty TNT, Valair 3600DD, DiPricol's, Home made intake w/ amsoil filter, Straight Piped w/ 7" tip, silencer ring MIA, glove box sticker MIA 2/28/09-470hp/980tq IBEW 551-PACIFIC COAST DIESEL |
#29 (permalink) |
ya header do actually reduce egts lol its because the air is spread out and isolated in the pipes and actually radiates the heat out of the pipes. which actually is only good for egt drops but a good coated set can be a huge improvement to air flow and spool time the coating will keep the heat and the longer primary pipes with increase velocity and move the heat away from the cylinders faster and keep more useable btu in the pipe system to power the turbine so if they have a good coating and equal length primary pipes to maintain a even velocity then these should be good headers and have no reason for not reducing egt from the 150 to 200 range do you have an addition bracket to mount just before the turbo to support weight and fatigue?
96 gmc 6.5 turbo hd/hp 80hp computer, kandn intake,4in exhaust,hx40 6 blade 60mm/9cm exh hous.new high perf inj pump and delphi pmd w/ #9 resistor, looking into getting injectors edmed/ and upgrading lift pump to a delphi model |
#31 (permalink) |
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper. |
#33 (permalink) |
how much would those cost??????
99 dodge 3500 5 speed- FASS 95 hpfp, CFM intake manifold, K&N air filter, Boost elbow,gauges-fuel pressure/boost/EGT bosch 40 hp injectors, edge comp and MBRP 4" exhaust
#35 (permalink) |
Super Moderator
![]() Join Date: May 2008
this has made me curious. what kind of material is it made out of? good looking header by the way. that thing is wild looking.:thumbsup
DUKE<-- 2000 4x4 3/4 ton ex cab lwb ATS converter,suncoast heavyduty rebuild kit,ATS valve body, edge EZ, straight piped, 3rd gen cromeclads, isspro pyro boost fuel, FASS , coaltrain 150's |
#36 (permalink) |
Sure hope you can get us some numbers soon, might have to get one to put on before the fat and fatter sisters arrive
'98.5 CTD 24v: 150 Jammers, HOT COMP, CFM+, ATS 3 Piece, 62/12 Turbo (need more), W/M Misting (want more) , Volant intake, 33's, 3.55, 5" exh w/6" bull horns, 1/2" f/ line > relocated f/pump, torque lock switch, built trans. + '06 Megacab
