GVWR for 1 ton crew dually - Dodge Cummins Diesel Forum
Towing & Hauling Discussion of Towing & Hauling Habits
post #1 of 13 (permalink) Old 11-27-2008, 01:34 PM Thread Starter
Question GVWR for 1 ton crew dually
Does anyone here have a truck like mine in my sig? I have 4.10's in the rear, it is 4wd. The reason I'm asking is my door sticker is all messed up and not readable. I spent a good half hour searching the forums but I really need to know my GVW and possibly axle weight ratings. I know my truck weighs 8100 lbs. with a tank of fuel, toolbox, and my fatass in the seat. I'm just getting annoyed of getting crap at the lumber yards when I load her up. 40 sheets of OSB doesn't even sit on the helpers. thanks everyone.
2004.5 QC DRW 3500 99,000 miles
1999 QC 3500 DRW utility body 300,000 miles
1997 EC LB 2500 280,000 miles
greenmtn. diesel man is offline
post #2 of 13 (permalink) Old 11-27-2008, 01:39 PM
moparguy2004's Avatar
I have a 2003 drw 4x4 4.10 and my gvwr is 12000 lb
My Rear Axle Gawr is 9350 lbs
My Front Axle Gawr 5200 lbs
2003 Dodge 3500 Laramie Sport,
moparguy2004 is offline
post #3 of 13 (permalink) Old 11-27-2008, 01:47 PM Thread Starter
thank you for quick reply. So I can safely put 3500 in the bed. What about GCWR just for curiosity's sake? thanks.
post #4 of 13 (permalink) Old 11-27-2008, 04:40 PM
newfy's Avatar
12,200 is what the sticker says on my truck
NEWFY
07 3500 dually 4X4 laramie, auto, patriot blue
newfy is offline
post #5 of 13 (permalink) Old 11-27-2008, 07:08 PM
Crazy Cooter's Avatar
Pleeeeease........your truck will scoff at 3500#.
You might make sure tire pressure is up to the task though.
Tony--KI6WAO 06 3500 QC 4x4 Dually:Smarty,Garrett Stage 2,SouthBend 3250 DD, 4.10's,Diamond Eye 4", RLB490's on 22.5" Freightliners,N-Fab Nerf Steps,Diamond Back ATV Hauler,B&W Turnover Ball w/ 5th Wheel Companion, Firestone's, Levi's blanket/turbo boot.
Crazy Cooter is offline
post #6 of 13 (permalink) Old 11-27-2008, 08:29 PM
haulin-rv's Avatar
Yet my Mega dually is 10,500 gvwr.
2016 Loaded Mega Laramie 2500
haulin-rv is offline
post #7 of 13 (permalink) Old 11-27-2008, 09:56 PM Thread Starter
I know, I know, she will carry much more, just wanted to know legally for the anal criticizers that I seem to be running into lately. I always run my tires at maximum inflation in all my vehicles, who knows when the tires are going to be called upon. by the way, what is the stock tire size? I almost got pulled over a couple of days ago, got clocked at 79, cruise was set at 70. What should I enter in the smarty for height? Thanks guys appreciate the help.
post #8 of 13 (permalink) Old 11-27-2008, 11:59 PM
You have 36" tires? They would have to be for your speedo to off that far.
You could have an independant shop that has a Snap-on scan tool recalibrate if you dodn't have a Smarty.
I reset pinion factor for pre 2006 trucks all the time with mine.
post #9 of 13 (permalink) Old 11-28-2008, 09:52 PM
J&L
not sure what state your registered in but in my state its a misdeamor to destroy, remove, alter, cover, deface or counterfeit the GVWR/GAWR door tag.
If your a dot legal commercial hauler see this from FMCSA 390.5 regs :
390.5 Definitions
Question 3: If a vehicle's GVWR plate and/or VIN number are missing but its actual gross weight is 10,001 pounds or more, may an enforcement officer use the latter instead of GVWR to determine the applicability of the FMCSRs?
Guidance: Yes. The only apparent reason to remove the manufacturer's GVWR plate or VIN number is to make it impossible for roadside enforcement officers to determine the applicability of the FMCSRs, which have a GVWR threshold of 10,001 pounds. In order to frustrate willful evasion of safety regulations, an officer may therefore presume that a vehicle which does not have a manufacturer's GVWR plate and/or does not have a VIN number has a GVWR of 10,001 pounds or more if: (1) It has a size and configuration normally associated with vehicles that have a GVWR of 10,001 pounds or more; and (2) It has an actual gross weight of 10,001 pounds or more.
A motor carrier or driver may rebut the presumption by providing the enforcement officer the GVWR plate, the VIN number or other information of comparable reliability which demonstrates, or allows the officer to determine, that the GVWR of the vehicle is below the jurisdictional weight threshold.
'05 3500 DRW 4x4 Jacobs
30' GN Starlite 20k flatdeck
29' RK 5th wheel RV
J&L is offline
post #10 of 13 (permalink) Old 11-28-2008, 10:06 PM
youngcummins08's Avatar
I think mine is 13000
my rig
96 2wd reg cab 2500, 405k miles, sport conversion, K&N. Replacment airfilter, homemade 4in.
youngcummins08 is offline
post #11 of 13 (permalink) Old 11-29-2008, 07:38 AM
cumminz's Avatar
If you haul real heavy the weak point on a dually is the wheels. They are rated at 2600#s. Best bet for safety and handling is go with 19.5s
CumminZ
2007.5, DRW 3500 BFT, Smarty S-67, 4x4, 3.73LS, 988s, 68rfe, Cool Hose, MBRP 5", Dual AMSOil ByPass, Mobil 1. Yukon free spin, '17 CC Champagne,
cumminz is offline
post #12 of 13 (permalink) Old 11-29-2008, 08:36 AM
haulin-rv's Avatar
You can also have any dealer (Dodge of course) run the vin and it will tell you what you truck is. Then simply go weigh the truck without the payload and you'll know what your capacity is. I just took my truck and trailer to the scale and weighed it to see what my max load was, $9 at the truck stop.
