Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Towing & Hauling
Towing & Hauling Discussion of Towing & Hauling Habits
Old 03-05-2009, 12:12 AM   #25 (permalink)
Heavy Engine Technician
Cutterw's Avatar
2001 with 160k miles. The first 60k it was hooked on a 3car hauler with the dealer ship. I've owned since 60k and have half towing a 36ft 3horse slant with Edge/Att on Stage 2. Stage 5 when just cruising which is putting about 320Hp on the ground.
2001 Dodge 2500 4x4 Edge/Att Coaltrain 100's BHAF with Custom Shield Airdog 150 5in Straight Exhaust Recon 3rd Brake Light Double 12 Boston Acoustic Subs with Diamond 400W Amp 382Hp/822Tq 15.6 at 88mph
Stock Turbo and Stock Transmission
Cutterw is offline   Reply With Quote
Old 03-07-2009, 03:34 PM   #26 (permalink)
my personal truck is 98u dodge 2500 with the 360 v8 gasser in it and it has 232000 on it and the trany so faris doing fine... slips a littile in over driver
tf416 is offline   Reply With Quote
Old 03-07-2009, 08:55 PM   #27 (permalink)
98andahalf's Avatar
snapped the input shaft on mine, put a new one in and two days later it wont shift into 2nd in wide open throttle. Also wont shift into 2nd manually
98.5 2wd. DragComp, 150's, HolleyBlack,CatTurbo (~42psi), adjustable FPR,T/C switch,custom 6" Stack, 2stage nitrous, custom Billet Single Disk T/C, rebuilt 47re w/ v/b&shift kit. fastest 2nd gen in GJ: 13.6@105, 2.5 60ft
98andahalf is offline   Reply With Quote
Old 03-08-2009, 07:57 PM   #28 (permalink)
if im not mistaken second gear is run off a band not the clutch pack so your band is probly burnt out ... well it could be couple things but it does have to do with the band and its components ... but im just guessing ...
Old 03-09-2009, 03:16 AM   #29 (permalink)
just had mine rebuilt. $2352.
I was doing about 10 mph, no load in the bed, no trailer flat ground and it reved up and that was it
AquaHero3 is offline   Reply With Quote
Old 04-17-2009, 02:22 PM   #30 (permalink)
Angry Welll
Mine is in the shop right now. 2nd time the bearing/bushing holding the input shaft in has bitten the dust.
3500 dollars each time.
Bill46 is offline   Reply With Quote
Old 04-17-2009, 07:08 PM   #31 (permalink)
Hey all, HTS is the way to go. Dusty fixed me up and left some $$ in my pocket. All I can say is WOW I never thought a transmission could perform like this one!
mr4bbl is offline   Reply With Quote
Old 11-03-2009, 05:35 PM   #32 (permalink)
bluesport24v's Avatar
47re Troubles
I also have the same problem, when the tranny is cold it goes into limp mode until i turn it off then turn it back on. I was told that was a problem resulting in torque converter drainback. Ive considered goin ATS but i cant afford one right now, but now i believe my trans may be goin all to heck, the fluid is discolored. Im takin my truck to get the tranny serviced asap. Also my truck has 155,000 on it with no problems yet except for limp mode and once it reaches operatin temp its fine, or once the converter fills up with fluid, i have heard the pump doesnt run while in N or P??? i dunno if thats true or not but im just throwin that out there.
bluesport24v is offline   Reply With Quote
