How much does your truck weigh? - Dodge Cummins Diesel Forum
Towing & Hauling Discussion of Towing & Hauling Habits
post #1 of 31 (permalink) Old 03-31-2013, 04:02 PM Thread Starter
Bigwheels94's Avatar
How much does your truck (empty) weigh? Reason I ask is that for many years now both local scales (dump, & weigh station) have had my 2500 (as in sig) weighing in at 7600 lbs +/- for fuel, etc. Now, suddenly they both are saying I'm at 8200 lbs. I know I have not added 600 lbs to my truck, & I haven't gained any weight myself. Next time I'm nearby, I'll run through the Cat scales to find out for sure. But as a result of this discrepancy, I don't know what I weigh with my camper loaded either. I know it's bringing me above my GVWR some, but according to the local scale recently it has me @ 12,760 lbs!!! According to my calculations, I MAY be as high as 11,000 with full complement of gear for a month of hunting. My tires are rated for 3650 lbs, & the rims I have are rated for 3500 lbs.
So, what do you think?
04.5 2500 QC LB, SRW,3.73 LS, UDC, HTT62/65/14,HTT SS Man,AFE II PG7,5"TBE, 51" Donaldson,Goerend trans, & Tripple Disc, Lam Flex,Billet Input,95 GPH LP,SnowII,Gauges-EGT(pre/post) BD X-Mon,Insite Monitor,Helwig Sway Bar,Firestone Bags,285/70/17 AT's
Bigwheels94 is offline
post #2 of 31 (permalink) Old 03-31-2013, 04:17 PM
12valvedriver's Avatar
Not that its gonna help you much but my second gen with me sittin in it is about 7200 and my first geb reg cab is 5700 with me sittin in it. I believe my parents 04 qclb is about 7600 and the 04 qclb drw is about 8200
'97-5" straight #100 ff, 19*, 4k gsk, AD II 165, valair dd clutch, 1-3/8" billet input, ARP studs, 60#, BD Super B over s475, 024's, Mayville WI best 5x14's,
'90-4" exhaust, kdp killed, pacbrake, 60 lb springs
12valvedriver is offline
post #3 of 31 (permalink) Old 03-31-2013, 05:06 PM
I usually scale at 8 empty with my 11 2500 Laramie. I have a rack, assorted chains and straps and dot gear in the truck all the time.
2011 2500 3.73 Laramie h and s tuned mild with 4inch straight pipe
misfitracer25 is offline
post #4 of 31 (permalink) Old 03-31-2013, 10:42 PM
7,300 lbs. w/full tank of fuel for the truck in my sig.
pronstar is offline
post #5 of 31 (permalink) Old 04-01-2013, 08:27 AM
beauabston's Avatar
I'm 8400lbs with me and just basic tools in toolbox. Your being a 2500 4x2, I don't see how your over 8k lbs. Even with 4x4 it still shouldn't be.
07.5 Dodge 3500 dually 4x4, Big Horn, QC, Anarchy EFI, MP8, AiRaid intake, Fireringed, ARP 425, 2in Skyjacker, BD track bar, Moog parts, G56/3:73, SBDD 3250.
07 Dodge 2500 4x4, QC, Anarchy EFI, AiRaid intake, 2in Rough Country, 48RE/3:42
beauabston is offline
post #6 of 31 (permalink) Old 04-01-2013, 05:03 PM
jeeper78's Avatar
I think mine was about 7600# with me in it and an almost full tank of fuel last I checked on my scales at work.
03 3500 SRW QCLB, HO, 4x4, Triple-Disc TC, Billet input shaft, HD Flexplate, Maghytec Pan, Patriot Blue/Silver, Level kit, 35x12.50x18 Open Country M/T, Method Fat Five, HBS Control Arms, Smarty Touch, Muffler Delete, Ride Rite Air Springs
jeeper78 is offline
post #7 of 31 (permalink) Old 04-01-2013, 05:33 PM
8005. 1/4 take fuel and an empty McDonald bag.
03 quadcab 4x4 6 speed. 3500
Sent from my DROID BIONIC using Tapatalk 2
03 Quad Cab Longbed Dually. High Output 6 speed manual. All stock except for Superchips Vivid Lynq.
killfast11 is offline
post #8 of 31 (permalink) Old 04-02-2013, 11:41 PM Thread Starter
OK. I've been doing some thinking. I know that can be dangerous, but here it is.
IF the local scales are right, & I rolled out of here last fall @ 12760 lbs. This would be the 3rd-4th year I did this with the front axle @ 5300 lbs, & the rear @ 7300 lbs. I know my 11.5" AAM is actually rated for over 8000 lbs, my tires are rated for 3650 lbs, but my wheels are rated for 3500 lbs. What to do?
I could get a set of black XD 808's rated for 3600 lbs. Or I can get some Type 81's with 265/70R 19.5 for lets say a lot more $$$. Or I could convert to a dually, for even more $$$$. I think the scales here are lying to me anyway, & I rolled out last fall @ about 11200 lbs, probably a little less so I was probably only @ 6000 lbs on the rear axle.
What would you do? (buying another truck is a NO GO, so don't even say it!)
post #9 of 31 (permalink) Old 04-02-2013, 11:44 PM
Danderson's Avatar
#6500 for mine per public scale for DMV.
'07 2500 SLT,5.9,regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Toyo AT2's. Dynatrac freespins and bj's. Synergy HD steering. Don's Kings. Anarchy EFI. Personally serviced.
Danderson is offline
post #10 of 31 (permalink) Old 04-02-2013, 11:50 PM
63boxtop's Avatar
8200 lbs
4x4 QC Dually with me and 1/4 tank of gas with some basic tools on board
2010 Deep Water Blue CCLB Dually 4x4, 68rfe 3.73
63boxtop is offline
post #11 of 31 (permalink) Old 04-03-2013, 12:36 AM
WildKyle's Avatar
My SRW 3500 4x4 weighted 6700 without me in it the other day and 1/4 of full
'11 F150 EC 6.5ft Bed 4X4 5.0 Coyote. Not exactly a Cummins...
'04 3500 QCSB 4X4 305/555. 48RE. SOLD
'01 2500 RCLB 4X2 235/465. NV4500. STOLEN
WildKyle is offline
post #12 of 31 (permalink) Old 04-03-2013, 12:41 AM
Master of Mayhem NASFIG
rpage's Avatar
your rims are rated for 3500 each which means 14k and you were at 12k. Seems to me that you dont have a problem unless i missing something.you have the same axle as a dually
rpage is offline
