18000lbs. What To Do ? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Towing & Hauling
Towing & Hauling Discussion of Towing & Hauling Habits
Old 05-02-2012, 06:54 AM   #1 (permalink)
I have had a Raptor toy hauler that had been in the 17000lb range. It pulls no problem with my airbagged Goerend 2500. My truck has been pulling 10000-17000lbs since new with no problems. I now have purchased a Cyclone 3800 which will be in the 18000lb range with 400lbs more on the pin. My truck is not a dually. What would be the ideal truck for this load ? It seems even a 1 ton dually (06-09ish) still dont "legally" pull the weight. It seems like axle weights went way up in 10-11. Whats realistic ?
2004 Cummins 2500 SLT 4X4, Georend 48RE Built, Smarty JR, S&B CAI, Espar D5, AirDog 2, Xenon Flares, Di-Pricol EGT/Boost/Trans Temp/Fuel Pr/Rail Pr, Hankook 285/70/17 RF-10, Killer JL Audio System, Mag Hytec Pans and Covers
summitboy is offline   Reply With Quote
Old 05-02-2012, 10:26 AM   #2 (permalink)
One thing Id be looking into at that wieght is a CDL. My understanding is even if its not a commercial vehicle @ 26001 pounds you are required by DOT to obtain a CDL. I may be wrong and Im sure someone will correct me if I am. Id be looking at a 3500 drw or a 4500 but then you got to be looking at the combined wight too(cdl issue if it applys) but I also doubt DOT will be hunting not for hire vehicles hauling a camper unless they want to be a azz...
EDIt: just saw your location is out of the USA. Forget everything I jsut said about the CDL thing...
tomsws6 is offline   Reply With Quote
Old 05-02-2012, 10:30 AM   #3 (permalink)
Cdl is only required in this case if used commercially.
2007 Dodge 3500 Quad Cab 5.9 Automatic.
All Stock.
Roadmedic is offline   Reply With Quote
Old 05-02-2012, 10:32 AM   #4 (permalink)
Is that in the US or Canada?
Old 05-02-2012, 10:38 AM   #5 (permalink)
US.
Truck and trailer gvwr combined if over 26,001 lbs.
If cdl then actual weight.
All Stock.
The Following User Says Thank You to Roadmedic For This Useful Post:
tomsws6 (05-02-2012)
Old 05-02-2012, 12:44 PM   #6 (permalink)
CumminsDieselSoot's Avatar
You dont need a cdl as long as it is for private use. You can use your truck to pull it and be fine. If your worried about the weight rating of the truck than have it raised at the DMV. I can do that here. I can have it set at any weight I want. It just cost more the higher the weight. I was told this at the port of entry here in Utah when I got my over lenght permit. I pull 22k all the time and Im 75 feet long. Were only alowed to be 65 feet without a over length permit. With the permit Im allowed to go to 77 feet.
Former Marine. 2004.5 QCSB, ATS stage 4 tranny, Smarty S06 POD, Banks high ram, Amsoil EaAU4510 air filter , intake muffler MIA, turbo silencer ring MIA, strait thru muffler, issopro guages, firestone air bags, on board air compressor with 5 gal air tank, train horns.
CumminsDieselSoot is offline   Reply With Quote
Old 05-02-2012, 12:49 PM   #7 (permalink)
1stgen3rdgendodge's Avatar
No need for a CDL just a Class A license if your going to be over 26,001 lbs. CDL is only needed for commercial use.
01 2500 QCSB 4x4 - NV4500 Swap, 3600# SD from Kenny's, Quadzilla ADR 4k, 150HP Jammer Nozzles, RSD 4" Down Pipe-5" Straight Pipe, AEM CAI, Raptor 150, Big Line Kit Tank to VP, Leveled, Recon Smoked Cab Lights (110# Springs, HD Rods, Head Studs, in the works)
1stgen3rdgendodge is offline   Reply With Quote
Old 05-02-2012, 01:21 PM   #8 (permalink)
Sorry, what do you mean you can raise the weight of the vehicle ? This is private use. How does one change the Dodge weights ??
Old 05-02-2012, 01:30 PM   #9 (permalink)
My truck is listed at the DMV as 12,000 lb qvwr. The D.O.T. Officer at the port of entry said i could raise that rating at the DMV. It just requires me to reregister it at a higher weight rating. It just cost more to do this.
Old 05-02-2012, 04:00 PM   #10 (permalink)
When I bought my 1 ton dually and went to get the tags I was asked how heavy I thought I would be. I really had no clue. So I just guessed and said total I would never be over 28,000lbs. I knew this was more than I would ever weigh but I thought better safe than sorry. I paid a little extra and got a sticker that said 14 tons that went on the plate. This was in Nebraska so who knows how it works where you live. This is just what I went through with mine. No paperwork, no questions, just a guess and a little extra money. When I say a little extra it was less than $20 if I remember right.
Later
Brandon
2006 QC 3500 6 speed Dually 5.9 HO Cummins. Only mod right now is an exhaust brake.
Hitparade is offline   Reply With Quote
Old 05-02-2012, 07:11 PM   #11 (permalink)
UtahBruteForce's Avatar
My Dually tows 19k regularly without issue. Hit the weigh stations a few times to check front/rear axle, pin weight and trailer axle weights. I've yet to surpass sticker weight limits on anything.
Dually is a MUST though for a rig that big -- but I have seen people tow with a SRW.. I'd never do it, but others do.
2009 Ram 3500 4x4 Mega Laramie/Resistol DRW
BFG MT KM2, 3.73 Gears, 18K SuperGlide, P3, Airbags, -&+DPF/EGR, Black Maxx w/OD, +&-Flo-Pro, Mag-Hytec Trans. Pan, Mag-Hytec Diff. Cover, 6" MBRP Stainless Tip
2010 Road Warrior 395 5th Wheel Toy Hauler (42')
2005 & 2008 Kawasaki Brute Force 750i (with everything!)
https://thechive.files.wordpress.com...if?w=200&h=270
UtahBruteForce is offline   Reply With Quote
Old 05-02-2012, 09:37 PM   #12 (permalink)
Age Quod Agis
unless those axles on that trailer are 10k axles or tripples, he is not even close to needing a cdl or a class A. they go by what you can haul not what your hauling.
rpage is offline   Reply With Quote
