Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Towing & Hauling
Towing & Hauling Discussion of Towing & Hauling Habits
Old 10-22-2009, 01:16 AM   #1 (permalink)
slowlt1's Avatar
Narrow neck gosseneck and a short bed?
I have a 07 6.7 4x4 short bed srw and want to haul heavier loads and am looking at goosenecks. Will the narrow neck trailers solve the turning problem?
slowlt1 is offline   Reply With Quote
Old 10-22-2009, 01:24 AM   #2 (permalink)
As long as you dont buy something that has a full 8ft wide nose then you wont have an issue. Not sure what kind of trailers you are looking at but my parents sell horse trailers and even the big ones can be pulled with short beds. You can custom order a full width nose but standard most are narrowed a little. My long bed got totalled and I am actually looking for a short bed now and I still haul for dad all the time.
tgibbs is offline   Reply With Quote
Old 10-22-2009, 01:30 AM   #3 (permalink)
slowlt1's Avatar
maybe not this one but something with the same neck design thanks for the reply. 22GN Tandem Dual Axle Gooseneck Trailer
Old 10-22-2009, 04:23 AM   #4 (permalink)
yoda's Avatar
i've pulled that style gooseneck many times and i have stacks and haven't had any issues yet. other then the bed touching the trailer from an off-cambered road going to an ORV park. just make sure you don't jack knife the trailer bad and you will be fine.
05 2500 qc, sb, 4x4, g56, 3.73, mp8, afe stg 2 pg7, 4" dynomax bullet muffler to resonator to 5" turnout stacks, ranch hand bumper, HBS 2" leveling kit, 295 HP/540 TQ feb 08 (stock), looking for donations
yoda is offline   Reply With Quote
Old 10-22-2009, 04:40 AM   #5 (permalink)
RoadDog's Avatar
From my pic you can see what i tow. Trailer has the 8' square nose and I even got a headache rack . I use a 16" offset hitch. I have to be careful of where I'm going, it is possible that I could get in a bind if I pull in somewhere with no escape route planed. I always stick to the truck stops though for the extra room when fueling. If you are careful you shouldnt have to worry about anything. I have learned to stay away from couldesac's and any other similar turning situation. Learned this the hard way. Trailer has abig dent in one of the corners. Without the headache rack it would have been the cab and the rear glass that would have gave way.
2008 6.7L Mega Cab Dually - Stock Everything -70 k prob free miles - Custom Diamond Flat Bed w/ Headache Rack - 36' Enclosed gooseneck car hauler w/ 16" offset hitch - 85 gal direct feed auxiliary fuel tank - Firestone "Ride-Rite" air bags on rear
RoadDog is offline   Reply With Quote
Old 10-22-2009, 10:11 AM   #6 (permalink)
DirtyDiesel1988's Avatar
i pull a 40' toy hauler with mine. its a full 8' across. tho on my 5th wheel hitch i have to slide it back to the "manuvering" position or itll hit my cab. the manuvering slides the hitch back about a foot or so.
2007 Dodge Ram 3500 MegaCab SLT 4x4 SRW 6.7 Cummins. LED Taillights, Projector CCFL Headlights, HID Highs Lows & Fogs, Home Made Brite Boxes, leveling kit, 5th wheel/Gooseneck Rails, PML Diff Cover.
DirtyDiesel1988 is offline   Reply With Quote
Old 10-22-2009, 12:52 PM   #7 (permalink)
jomac11's Avatar
I can turn our 20+5 PJ gooseneck past 90 degrees with my shortbed and the neck on it is full-width.
08 Mineral Gray Metallic Quad Cab SB, CTD, Auto
20x9 KMC XD Badlands, Chrome, 325/50/20 Mickey Thompson ATZ
jomac11 is offline   Reply With Quote
Old 10-22-2009, 01:14 PM   #8 (permalink)
slowlt1's Avatar
great info thanks guys
Old 10-22-2009, 03:40 PM   #9 (permalink)
TEX
TEX's Avatar
you will be jsut fine unless your trying to go past 90* or something and then your trying to rip the tires off the rim lol
just make sure you set the height on the neck right and watch it going threw dips. if the trailer drops down to much there goes a tailgate or bed rail
2006 Mega 3500 DRW 4X4 G-56 SLT Optix EGT,Boost,Trans-4510 W/Cool hose kit
2008 Keystone Copper Canyon 298FWBHS
Wake Up America
TEX is offline   Reply With Quote
Old 10-22-2009, 07:31 PM   #10 (permalink)
slowlt1's Avatar
I will be hauling it through the fields on a regular basis is there a certain design or neck i should look for to keep from contacting the bed rail?
Old 10-22-2009, 09:38 PM   #11 (permalink)
TEX
TEX's Avatar
they are pretty much all the same. while you want the trailer to sit as level as it can. you can raise the neck of the hitch, extend the vertical pipe, a bit to help.
what kind of gooseneck hitch are you going to get?
Wake Up America
Old 10-22-2009, 10:10 PM   #12 (permalink)
slowlt1's Avatar
A buddy rolled his rig and is parting it out and said for the help i gave him i can have his B and W turnover ball. Cant beat free.
