Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Towing & Hauling
Towing & Hauling Discussion of Towing & Hauling Habits
Old 10-17-2009, 03:51 PM   #1 (permalink)
Towing 38'-40' toyhauler with a manual trans
Did you do any trans mods? If so what?
2006 white quad cab Dodge dually, G56, True Flow XDI air filter system, FilterMag, am/fm/cd/sirius, Fluidampr, LineX bedliner, 3.73, gooseneck hitch, Mag-Hytec rear diff cover, rear bags w/ in-cab controls, P235/80R17 Michelin LTX M&S on stock wheels
Moparman is offline   Reply With Quote
Old 10-17-2009, 10:47 PM   #2 (permalink)
CowboyCummins01's Avatar
synthetics, full fluids, oil cooler... and maybe later on get it built up with heavier duty parts. if i remember corectly the G56 isnt as strong as the NV5600.
2001 Ram 2500HO, NV5600, Just an ol ranch truck,362rwhp,811ft/lbs 10/24/09
Just Ledoux it-RIP Chris Ledoux
CowboyCummins01 is offline   Reply With Quote
Old 10-17-2009, 10:51 PM   #3 (permalink)
Let her rip, then when the clutch gives way later down the road, just get a 3250DD and never worry about any problems again!
08 Mega Cab 6.7 6spd
-EGR/DPF/5"TBE with XRT except now I need a new clutch...
jrpro130 is offline   Reply With Quote
Old 10-18-2009, 10:10 AM   #4 (permalink)
haulin-rv's Avatar
I pull a 50 foot wedge with 3 cars on daily, no troubles here. Heck my stock clutch went 190k.
2007 Dodge Mega Dually SLT, 5.9 Cummins, G56 6 Speed , Recon LED's, 76 Gallon Aux Tank, 24k Husky 5th Wheel, Muffler Delete, Amsoil, and Infiniti sound system.
184,149 miles as of 08/01/09
haulin-rv is offline   Reply With Quote
Old 10-18-2009, 10:58 AM   #5 (permalink)
get the trans-cool coolers and fill the g56 with two gallons of amsoil or other synthetic atf4. this is one quart for the cooler and one quart over full. the g56 needs this last quart for the front bearing. what jrpro130 is talking about is the 06 up has a dual mass flywheel of very poor design. i had three of them fail before 50,000 miles if i would of had them replaced under warranty they would have put a dmf back in. i chose to get the south bend kit for the trucks it has a solid flywheel that has a real pilot bearing a disk that does not slip and new hydraulics. the solid flywheel does transmit the noise more than the dmf so when you install it do not think there is something wrong. we tow very heavy with the 06 trucks and one has a temp gauge on it. they stay cool with the fluid and cooler
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline   Reply With Quote
The Following User Says Thank You to carl48 For This Useful Post:
Moparman (10-18-2009)
Old 10-18-2009, 12:54 PM   #6 (permalink)
Thanks Carl I wondered what a '3250DD' was, sounded like a topless dancer's bra.
Old 10-18-2009, 09:38 PM   #7 (permalink)
haulin-rv's Avatar
You can get them here direct and about $40 less than Geno's.
Old 11-03-2009, 07:33 PM   #8 (permalink)
Trans-Cooler
Has something happened to Trans-cooler? I tried to reach them at their phone number and email and nothing works. Are they out of bus?
Thanks/John
JShumate is offline   Reply With Quote
Old 11-13-2009, 05:18 PM   #9 (permalink)
Try this site John. Only one page but gives the phone number;
www.fastcoolers.com
Old 11-14-2009, 04:32 AM   #10 (permalink)
Offroadjunkie's Avatar
with my nv4500 id go anytime with that... i would just have to watch my rpms in 5th
1998.5 Dodge Ram 3500 4x4 5speed only cold air intake, 50hp injectors, 3 piece manifold for now. Came with bags that are not hooked up
Offroadjunkie is offline   Reply With Quote
Old 11-14-2009, 10:58 AM   #11 (permalink)
trans-cool and fast cool are two different companys the trans-cool is a lot better product and works better
Moparman (11-14-2009)
