Old 11-25-2008, 10:30 AM   #1 (permalink)
VolCTD's Avatar
19.5 vs road hazards???
I'm looking at getting a set of 19.5's for my 2500 to help tow my 5th wheel with. Some reasons are the extra tread life plus the extra weight capabilities but how much better do they hold up against blowouts? I'm assuming due to the extra thickness of the rubber and extra plys that they are much better than stock tires (265R70 17). What are some of your alls experience with them towing?
Thanks!
2003 Dodge 2500 5.9L SLT 4x4 Quad Cab LB,47RE, 3.73 Gears, Quad XZT+, ISSPro Gauges-Boost,EGT,Trans, Recon Smoked Cab Lights, Vision 19.5 wheels,Hankook DH01's, PacBrake Airbags
2008 Denali 5th Wheel 28LBBS
VolCTD is offline   Reply With Quote
Old 11-25-2008, 10:42 AM   #2 (permalink)
Over Fueled and Budget
Magic smoke's Avatar
I've only seen them on duallys.
Early 04 3500 drw quad cab-6speed SBC fast coolers - 4x4 -S&B -fass 150-expandit 5"- FTE resonator -SMARTY-autometer C2 full pillar gauges- di-pricol rpg-Dragonslayer cp3-64/71/14-PDI manifold -Wicked 125's - $2 rail cap.
Magic smoke is offline   Reply With Quote
Old 11-25-2008, 11:07 AM   #3 (permalink)
Diesel Nut Motorsports
Diesel Nut's Avatar
I had 19.5's on my 03 dually. Towing they were beyond awesome. I will say that you will want to do plenty of research on shocks, as the 19.5's will ride much rougher and you will want to find a shock that will take some of that up.
.com
Not just an online vendor, we are your #1 source for parts, service and installations! Custom transmission and motor builds as well!
Our Amsoil webpage
Become an Amsoil Preferred Customer
Become an Amsoil Dealer
Diesel Nut is offline   Reply With Quote
Old 11-25-2008, 11:14 AM   #4 (permalink)
I just put a set of dura grapplers on thusday and they ride alot stiffer than anything I've ever had. They have tons of tread also. You might save some money and check them out.
Old 11-25-2008, 11:24 AM   #5 (permalink)
VolCTD's Avatar
Yeah, I was looking at also adding a set of Bilstein Silver/Black shocks since I'm sure the OEM ones are shot. Just trying to find as much ammo to convince the wife that it's a good upgrade. I'll also be adding a set of PacBrake airbags at the same time.
