Old 07-27-2009, 07:21 PM   #325 (permalink)
Hi guy's,
I've been watching this awesome thread with much interest. I've got a 04' with a 2" leveler.
My 35" Procomp AT's are shot and it's time for a new set of tires.
Problem I have is most here are stating that a rim with increased BS will cause fender rubbing. Seems that a stock rim off-set at 1.7" would cause more inner fender rubbing than more off-set.
I'm running Micky T's Street-Lock rims and that rim is a 9" with a 5" BS (4" offset).
That's a big difference from stock, but the more neutral you are in relative to where the tire sits to the wheel mounting surface, the less "swing" the tire will make in an arc. Also with more BS, you are farther away from the control arms.
So the question is, why would more offset (wheel centered) cause more rubbing than with less offset (more BS) and thus eliminating my chance of running a 37" MTR.
Help!
--D
Rockrover is offline   Reply With Quote
Old 07-29-2009, 01:52 PM   #326 (permalink)
Originally Posted by cumminspower123 View Post
yes i have the Kore HP series. my truck rides a whole lot better with these tires and suspension compared to the stock suspension and tires. The highest point on the outside of the front fender was 39.5 inches before and 45 inches after the suspension kit and tires. the tires only rub at full lock on the control arms but i trimmed the back of the front fenders about .5 inch because it was too close and would rub if i was turning and hit a bump. And no rubbing when flexing unless i turn all the way
Truck looks great, so you said you trimmed part of your front fenders? or just the inside? If you trimmed the actual fenders I wonder if longer control arms would fix the problem so you don't have to cut into sheet metal.
07' 5.9
Lorenz, 35's
37's soon
pitrack is offline   Reply With Quote
Old 07-30-2009, 10:39 AM   #327 (permalink)
Originally Posted by NT2HLBLY View Post
speaking of tire wear... been asked alot about these tires. 40k plus... not 2 bad!
those have 40,000 miles from a 3/4 or 1 ton diesel? wow thats good!
onebadrubi is offline   Reply With Quote
Old 08-07-2009, 04:05 PM   #328 (permalink)
Always lost & Never found
NT2HLBLY's Avatar
thats rite!
2008-6.7-2500-go fast parts, 37s
1990-5.9-no fast parts... 37s
1991-YJ-go slow parts, 38s
1989-K1500 SBC soon to be on ROCKWELLS and 39.5s or bigger!
I do it on the rocks
NT2HLBLY is offline   Reply With Quote
Old 08-13-2009, 02:29 PM   #329 (permalink)
Hootie Hooo!!!
hpstran's Avatar
My dually with leveling kit and stock rims on 37's
I finally put the 37's x 12.5 on my stock dually rims with leveling kit and rear wheel spacers to see how they would fit and it fits perfect. There is only a small part of the plastic fender well in the rear that I will have to trim a little shorter-maybe an inch but it all fits! I did not see any rubbing in the front even at full lock. There might be some minor rubbing if I do some major off roading but that's it. Here are the pics!
These first three pictures are the front wheels at full lock---but no rubbing!
This is the inside of the rear dually wheels next to the leaf springs.
This is the inside rear fender well plastic that I will have to trim slightly---will take me maybe 5 minutest to do both sides with a razor blade and I bet you won't be able to tell!
This is the ORU wheel spacer I used!
These next pictures are of how far the wheel sticks out past the fender on the rear!
2004 Dodge Ram 3500 Dually, leveling kit, rear wheel spacer, AFE Intake, Flashpaq tuner, MBRP Exhaust, Fab Fours Front and Rear Bumper, Warn 16.5ti winch, In Car Computer Nathan K 5 Train Horns, High Performance Clutch, and other neat stuff![SIGPIC]
hpstran is offline   Reply With Quote
Old 08-13-2009, 02:43 PM   #330 (permalink)
NT2HLBLY's Avatar
that is badass!!!
The Following User Says Thank You to NT2HLBLY For This Useful Post:
hpstran (08-13-2009)
Old 08-13-2009, 03:40 PM   #331 (permalink)
Si vis pacem, para bellum
BroncoHound's Avatar
Dude, we NEEEEEEEEEEEEEEED pics of the whole truck. That is absolutely incredible.
'08 QCSB 4WD G56 3.42: 6000k HIDs, HBS Leveled, Carli-valved 5100s, Thuren track bar, SSSSS, 325/70R17 Nitto TGs, Ride Rites, ISSPRO EV2 Boost/EGT, Smarty, GHD, Shaved BlueTec badge
"Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter."
BroncoHound is offline   Reply With Quote
The Following User Says Thank You to BroncoHound For This Useful Post:
Old 08-13-2009, 04:22 PM   #332 (permalink)
NT2HLBLY's Avatar
Old 08-13-2009, 04:40 PM   #333 (permalink)
Diesel Inside's Avatar
I 2nd this statement
02 2500 2wd auto: superchips programmer, 4" turbo back straight exhaust, 5" stacks turned back, K&N intake, silencer ring removed, lowered, debadged, custom audio. AND debating ADR or JUICEhttp://www.cardomain.com/id/duster1971
Diesel Inside is offline   Reply With Quote
The Following User Says Thank You to Diesel Inside For This Useful Post:
Old 08-13-2009, 07:07 PM   #334 (permalink)
Hootie Hooo!!!
hpstran's Avatar
This is all I have for now before the 37's. I am ordering some Interco Vortracs 37x12.5x17 load e's now that I know they will fit. They should be in within the next couple of weeks.
Sorry she needs a bath here....lol! And I will post better pics with the Interco VOrtrac 37's as soon as they come in!
Old 08-15-2009, 03:08 AM   #335 (permalink)
Scott39's Avatar
Nice truck. What car computer is that in your truck?
And what tail lights are those?
<>< JC Rules http://www.hollandcourtsales.com/
New to me 10/08, 1995 2500 single cab 4x4 Cummins, 4.11 posi, 5spd, Gear vendors overdrive, dana 80, HB 2.5" level kit, rancho 9000`s
Scott39 is offline   Reply With Quote
The Following User Says Thank You to Scott39 For This Useful Post:
hpstran (08-15-2009)
Old 08-15-2009, 11:52 AM   #336 (permalink)
Hootie Hooo!!!
hpstran's Avatar
I got that carputer from Mobile Computing Solutions. I had some problems with it but dealt with a couple of guys there named Chris Wood and Alex and they got everything resolved for me quick. The tail lights are recon that I got off of ebay. The one on the tailgate I had to smoke myself because nobody sold it that way. Thanks for the compliments also!
