Old 10-09-2008, 09:20 AM   #1 (permalink)
booger30's Avatar
Wanting to know best backspacing for running 37"s!
I have a 2500 with a 6 inch lift and I plan to run 37's soon. I plan on going with an 18x9 wheel but would love to know what the best backspacing would be for the least amount of rub!! Thanks!!
booger30 is offline   Reply With Quote
Old 10-09-2008, 09:29 AM   #2 (permalink)
Pooter's Avatar
Try to stick to as close to stock as possible.
I know its kind of hard, since most aftermarket wheels are 4.5" backspacing, but try to be 5.25" to 6".
Im running 17x9 XD Hoss wheels with 5.71" backspacing and its perfect, no rubbing on the control arms anymore(at full lock, with the stock wheels) and not even close to rubbing the fender up front. Im only running 35s right now, but I ran 37s on stock wheels and the only rub I had was at full lock on the control arms(not bad, but annoying)
'07 5.9 Mega Cab 2wd/G56
Smarty, Green CAI/Amsoil filter, Guages, 5" TBE, 2.5" Drop Shackles, MyGig Nav
Pooter is offline   Reply With Quote
Old 10-10-2008, 01:56 AM   #3 (permalink)
joelliott's Avatar
as stated above, stay near the 5" backspacing. I had a similar 6" tuff country and 37x12.50 tires on 20x10 wheels with 4.5" bs. I rubbed on the fender corner. had to do a little trimming to clear. So you having a 9" wheel with a 5" bs would be perfect.
Joe E.
06' Dodge Ram 2500 Cummins 4x4 9"lift 38.5"tires
Joe E.
joelliott is offline   Reply With Quote
Old 10-10-2008, 08:39 AM   #4 (permalink)
booger30's Avatar
OK. Thanks guys. Thats what I was hoping. I would rather stick with a 10" wide wheel but had heard that 9" would work better so I guess thats what I'll do. Thanks again!!
Old 10-10-2008, 04:52 PM   #5 (permalink)
Do you have a picture of your truck from the back looking down the side? I'd like to see what the 5.71" wheels look like (how much they stick out).
2008 2500 6.7L, G56, 4x4, quad cab, short bed - 5" Expandit TBE w/ muffler, S&B intake, Shibby EGR & cooler delete, Valair 12.25" ceramic dual disk, Smarty 67, EV2 EGT gauge.
schloe is offline   Reply With Quote
