Old 08-21-2008, 11:32 PM   #1 (permalink)
load ratings???
Im looking at BFG rugged trail 265/75 16 for my '97, i want decent fuel milage for primarily a highway runner, now theres two load ranges present:
114 which can load 2601 pounds
and
123 which hauls 3417 pounds
so the question is, do I need the tires rated for more weight? im only doing two right now cause my front tires, installed by the PO, still have some life left in em.
thanks guys
PowerstrokeConvert08 is offline   Reply With Quote
Old 08-21-2008, 11:46 PM   #2 (permalink)
The lighter rated tires sound like load range Cs.
I wouldn't put anything less than Ds on a 2500 or bigger.
2007 3500 SRW Quad cab,long bed,Bighorn edition.
4x4,5.9,6spd,3.73s
Patriot Blue
SundayMoney is offline   Reply With Quote
Old 08-22-2008, 11:29 AM   #3 (permalink)
Gypsy's Avatar
yup, gives a smoother ride
Gypsy is offline   Reply With Quote
Old 08-22-2008, 01:07 PM   #4 (permalink)
Another thing to consider,other than the weight rating,is the air pressure each tire can take.
If your looking for mileage,get the higher rated tire. You can put more air in a D or E rated tire for less rolling resistance.
Less rolling resistance means more MPG.
4x4,5.9,6spd,3.73s
Patriot Blue
Old 08-22-2008, 03:04 PM   #5 (permalink)
HB69DART's Avatar
Plus with the higher load range tires, your tires won't be the limiting factor in how heavy you can tow.
2007 6.7 4x4 QC DRW, auto - 2" level, Dually Rockstars, Buckstop bumper, MBRP filter-back, S&B CAI, Amsoil bypass, de-badged, Bushwacker flares, Recon, Undercover tonneau
1969 Dodge Dart - 572" wedge
HB69DART is offline   Reply With Quote
