Old 08-21-2008, 04:07 PM   #1 (permalink)
Black Smoke Addict
RedRum's Avatar
BFG Tires....
So heres a little bit of a rant. I have some '37" BFG m/ts' on my truck. My brother just got some 37" Toyo m/ts. When we put them side by side his were about 2" taller. I asked a buddy who works at a tire place about this, and he told me that BFG makes their tires a couple inches shorter than what they say they are.
Not believing this, I went and measured my brand new 33" BFG m/ts on my crawler, and sure enough, they measure 31".
Why in the wide wide world of sports would they do something like this? Yeah, its not really a big deal, but if I am buying 37" tires, I would kind of like them to actually measure 37" and not 35". Also, its kind of disappointing to know my younger brother is actually running bigger tires!!!!
Ok,
2007 3500 QCLB, 5.9, ISSPRO, AFE Stage 2, AF1 intake horn, Smarty, SB 3600#, Straight Piped with 6" Mitres, 6" lift, Bilstein 5100s/dual steering stabs., trac bars 37" BFG M/Ts, CUMMINS FORUM STICKER!May 2009 ROTM-Thanks to James @ RSD for stepping up!
2006 3500 QC Bighorn, 6 speed, No silencer ring, B&W turnover, other than that, stock
"I Caught that diesel thing, now it stings when I pee"
RedRum is offline   Reply With Quote
Old 08-21-2008, 04:13 PM   #2 (permalink)
i have the 35" mt and my buddy has the 35"nitto and they are the same size
shultsz is offline   Reply With Quote
Old 08-21-2008, 04:30 PM   #3 (permalink)
THis is a common mistake alot of people make is they think just because it is a 35 or 37 inch tire it is actually that size but when you look up the manf specs some tires are alot diffrent than there size on the side of the tire. BFGs are one of the ones I know are usually on the small side. I feel this is also one reason some people have rubbing issues and others dont with certain lifts or spacers. Just one of those things that gets over looked.
99 Reg cab 2500 5spd, ad100, 5"ex, smarty revo,TST , guages, Valair 13" ofe, Mach 5, 62/71/14, 491.43 hp 964.04 uncorrected western nc dyno day.
jp8819 is offline   Reply With Quote
Old 08-21-2008, 04:34 PM   #4 (permalink)
Hawk62cj5's Avatar
Yeap just a marketing ploy IMHO . With that said some tires are larger then posted.
Hawk62cj5 is offline   Reply With Quote
Old 08-21-2008, 04:59 PM   #5 (permalink)
btolenti's Avatar
Yeah, my 315/70/17 Mickey MTZ's measure out to a little over 33" on my truck. Specs say they "should" be 34.7".... Weight and rim width play into it a bit though - but not 1.7"....
06 Silver Quad Cab 4x4 Automatic
-4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's
-Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11
btolenti is offline   Reply With Quote
Old 08-21-2008, 05:04 PM   #6 (permalink)
SootKing's Avatar
sucks man. my bros duramax has toyo 35's like my BFG 35's and they measure the same size
P-pumped 02 graphite,short bed,fass 95, KMC ambush 22's,100 horse sticks,icebox S&B, banks brake, NEW 215 p pump, 4gsk, laser cut dv's, 24 degree timing, street cam, DSS and solid steel 3rd gen trac bar, leveled, Fleece suncoast transmission, HID's, 8 in CAT stack
SootKing is offline   Reply With Quote
Old 08-21-2008, 05:10 PM   #7 (permalink)
bigblue24v's Avatar
its not that they arent actually 37", they have very weak sidewalls, and really cant handle the weight of these trucks, if you unmount them they will sit 37"
Old 08-21-2008, 05:10 PM   #8 (permalink)
Cummins Diesel ADdict
dom42's Avatar
how many miles do you have on you tires........
this is my 2nd set of 325/60/20 bfg's. and when i put the used one next to the new one, guess what, the new ones are taller. hmm i wounder why? ...just mess'n with u:thumbsup
no, but really how many miles do you have on them?
2006 2500 QCLB 4x4 auto-5" SilverLine TBE - cfm plus- s&b CAI system- 6 inch superlift- kore components- 325/60/20 bfg AT's- 20" motometal- fs2500 on engine & tranny- maghytec all around- 4.10gears- BullyDog Pmt w/crazylarry- truckcoverusa roll out cover- rhino linings- firestone bags- Nfab 6step- Thuren trackbar
k7gsxr1000- full race bike- ohlins all around-brembo masters-full ti arata exh-pretty much everything
dom42 is offline   Reply With Quote
Old 08-21-2008, 05:16 PM   #9 (permalink)
BowChickaBowWow
Brentc's Avatar
Could be the wheel as well. If you have a Factory Wheel that is 8" wide they will measure taller Vs. a after market wheel that is 10" wide which will have the tires a little smaller. I would not think 2" tho
07, 5.9, 3500 , Smarty, CAI, 2" Leveling Kit, 22.5 Alcoas w/255/70 Goodyears, 6" dual Miters, Smoked Out...
More to come with a little bit of
Brentc is online now   Reply With Quote
Old 08-21-2008, 10:06 PM   #10 (permalink)
dif. makes are dif. sizes thats y like some 1 said u ask for the actual hieght and u have to b measuring with tire dismounted
2001 2500, 6sp, luk ceramic clutch, 5inch lift, 5inch stacks, 36's, edge comp box, hyper programmer,150 hp inj., short throw shifter, air dog 150, newvp44, 3 guage pod, trucks in the garage- compond set up w stock 35 an a ht3b adjustable waste gate an some 7x.20's
bradley59dzl is offline   Reply With Quote
Old 08-21-2008, 10:22 PM   #11 (permalink)
Desl Pwr's Avatar
Humm, measure with the tire dis-mounted??? Not exactly. As said before, the side wall dimensions do not reflect the exact tire dimensions in most cases. Now depending on the manufacturer, usually there is a chart which lists the actual tire size. Some charts go further and list the rim dimensions on which the tire is mounted. So, as mentioned above, tire pressure, vehicle weight, side wall strength and rim width all play some role in the actual measured height of the tire. That said are all those factors going to combine to make a +2" difference....I'm thinking no, not that much.
On a side note, I had a set of 35" BFG Mud Terrains and I had two of them come apart at the side wall. One on the front, and one on the rear within 6,000 miles of each other.
'97 2500 CC 4x4 5spd - 4.5" lift w/ 35's, SBC DD, 100 plate, 4k GSK, DDP3's, stock turbo, AFE, 6" Mitre Cuts.
'03 3500 DRW QC 4x4 - SO 179hp/350lbft --
Desl Pwr is offline   Reply With Quote
Old 08-22-2008, 08:17 AM   #12 (permalink)
Super Moderator
Broke Down's Avatar
i think this is in the wrong forum. most tires on the market will measure smaller. the measurment is the dismounted measurement. plus you run a wide wheel shortens the heigth. narrow wheel will keep it the same. if yopu ever measure a 38" TSL it will measure 35"
DUKE<-- 2000 4x4 3/4 ton ex cab lwb ATS converter,suncoast heavyduty rebuild kit,ATS valve body, edge EZ, straight piped, 3rd gen cromeclads, isspro pyro boost fuel, FASS , coaltrain 150's
Broke Down is offline   Reply With Quote
