Old 08-19-2008, 08:40 PM   #1 (permalink)
MD Chapter President
RobertP's Avatar
35's and factory steel wheels?
i was wondering if anyone out there is or has run 35's on the factory steel wheels?
Maryland Chapter President. At your service.
[color="Blue"]05,5500,g56,II silver 66 second gen style!!, SBC DD,custom pumps and Injectors from II, Hamilton Springs, Smarty! 702.92HP 12.92@108MPH! SOLD
RobertP is offline   Reply With Quote
Old 08-19-2008, 08:43 PM   #2 (permalink)
TENNESSE CHAPTER VP
jonathanrayce's Avatar
My dad is running 35X12.50X17 Cooper STTs on his factory steel chrome wheels. He has a leveling kit. I believe they put 1/8"-1/4" spacers behind the wheels, but i am not sure. i will find out.
2006 2500 Quad Cab 4x4 auto - 3.73s, Smarty TNT, Edge EZ, AirDog 150, Studs, Springs, AFE Stg 2 CAI Amsoil filter and prefilter, Heater Grid and silencer mia, Cat delete and free flow muffler with 6" tip, 275/65/20s
jonathanrayce is offline   Reply With Quote
Old 08-19-2008, 08:52 PM   #3 (permalink)
puffthemagicgoat's Avatar
yes they will fit only rub i had before level kit was on control arms very little bit
2005 4dr 2500 4x4 II Super Phat Shaft 66 ,120's, Scarry Larry, Built Tranny, BD flywheel, BD lift pump,4'' exhaust,2nd gen intake, II modded cp3, AFE proguard 7, traction bars, weight rack, zex nitrous,17x12 pacers 33'' truxus 6in revtek Dunbars Dyno 527.57HP 994.00TQ
puffthemagicgoat is offline   Reply With Quote
Old 08-19-2008, 08:53 PM   #4 (permalink)
TENNESSE CHAPTER VP
I forgot to mention he has no rub.
Old 08-19-2008, 09:19 PM   #5 (permalink)
madakira's Avatar
35's on factory wheels with a 2.5" leveling spacer
Religions vary in their degree of idiocy, but I reject them all. For most people, religion is nothing more than a substitute for a malfunctioning brain. - Gene Roddenberry
madakira is offline   Reply With Quote
Old 08-19-2008, 09:34 PM   #6 (permalink)
lesbian at heart
elephantrider's Avatar
could you fit a 37" ? looks like a 37" would fit just fine !
im waiting for my level kit and wanted to get 315's or a bit bigger.
jason
04.5 6sp qclb whiskey tango foxtrot, over
elephantrider is offline   Reply With Quote
Old 08-19-2008, 09:58 PM   #7 (permalink)
madakira's Avatar
I hear they would rub a bit. I put that on about 3 weeks ago. Now I feel stupid because I am getting a 6 inch lift withing the next month. I am hoping a 6 inch will look ok with 35's. I can't afford to buy a new set of 37, when these are less than a month old.
Old 08-19-2008, 10:51 PM   #8 (permalink)
RobertP's Avatar
the reason for asking is that i have the 2.5 inch skyjacker on the truck now. im running a set of 33's well they are soon to be wore out. early next year i plan on a 4-5 inch lift. i figured that i could put the 35's on now and then when i get my lift i wont need to buy new tires. so just very minor rubbing unless i install a 1/4 inch spacer behind the wheel?
Old 08-19-2008, 11:11 PM   #9 (permalink)
madakira's Avatar
I haven't had mine rub at all. I might get some rub if i was making a tight u-turn. I think it would only rub at full lock with the stock rims. You should be fine. I was thinking of getting a 6" lift with some 37's and then maybe trying to fit some 39's later down the road. I like the look of the full wheel well.
Old 08-20-2008, 12:01 AM   #10 (permalink)
rpainter's Avatar
35 will not rub with the lift unless you run a 10" wide wheel and what kinda of 33 are you running now? I could use them when you are done with them. I need 1/4" of tread max Rob
2004.5 3500 stock for now (hoping for upgrades soon)
rpainter is offline   Reply With Quote
