Old 08-17-2008, 10:56 PM   #1 (permalink)
MS Chapter President
2141pete's Avatar
how will they fit?
Ok the wheels should be here along with new tires this week. The rims are pro comp 6001's 20x9 with 4.5" backspacing and a 12mm offset. I am doing 305/50/20 Toyo proxes ST II's. Anybody have any idea how these will look on a 2nd gen with a leveling kit?
2002 dodge 2500 4x4 24v, 175 pump, 4k GSK, 191 DV's, Mack plug, .093" lines and tubes, HD Cam, twins, 8x.011's, and a few other things
2141pete is offline   Reply With Quote
Old 08-17-2008, 11:10 PM   #2 (permalink)
speedntriple's Avatar
I'm wondering the same thing, can anyone give some input or advice here?
99 24v 4x4 5sp 5" str8, SB, AFE, AD150, ATS arc flow,Drag Comp, Jammer 4s,gauges,DSS, Ranch hand front/rears,steps, 18" Rockstars, 2" level, PSC
94 12v, 2wd, AT,#0, pump mods,built trans, dragon flows gauges in.ex
speedntriple is offline   Reply With Quote
Old 08-17-2008, 11:33 PM   #3 (permalink)
bigblue24v's Avatar
its going to be very low profile...and will probably stick out 4 inches or so
just for comparison, heres 35s on 20s for my truck...so knock that sidewall down to an inch on each side
Old 08-17-2008, 11:39 PM   #4 (permalink)
2141pete's Avatar
Thanks that's a good comparison. Different wheels and tires but exact same truck:thumbsup
Old 08-17-2008, 11:45 PM   #5 (permalink)
whats the backspacing on these?
Old 08-17-2008, 11:51 PM   #6 (permalink)
lawlorsd84's Avatar
will 35's fit an 02' with just a front levelling kit?
02 WHITE 4X4 2500 QC, SB, 4" EXHAUST, EDGE EZ, K&N INTAKE, LINE-X, BAJA MACHINE
lawlorsd84 is offline   Reply With Quote
Old 08-17-2008, 11:54 PM   #7 (permalink)
2141pete's Avatar
I have heard yes and no. I believe I have actually seen it done in pics before.
Old 08-18-2008, 12:06 AM   #8 (permalink)
bigblue24v's Avatar
4.5"
based on what i saw with the test fit, it looked like they stuck out 4 inches, the tires back 1" past that so theoretically, everything will stick out 5 inches
Old 08-18-2008, 12:06 AM   #9 (permalink)
bigblue24v's Avatar
depends on the wheels..most run 315s which are 11.5 inches wide, but iwht the right wheels, it can be done but not w/o a levelling kit
Old 08-18-2008, 12:16 AM   #10 (permalink)
josh brown's Avatar
You can fit 35" with a leveling kit, I've seen several but they were all on stock wheels. Wheel offset affects tire fitment as much as lift does. I've seen guys with 6" lifts running 33" tires because anything bigger will rub due to the 10" wide wheels and 4.5" back space. I think the stock backspace is like 6.5".
06 2500 4x4 QC SB auto Big Horn. Leveled, 325/65/18 on Ultra Predators, Smarty jr., S&B, Glacier bypass fuel filter system, Dipricol,50hp DDP injectors, AFE 4" turbo back with 30" magnaflow BD super B if I can ever get the time to hook it up
josh brown is offline   Reply With Quote
Old 08-18-2008, 12:23 AM   #11 (permalink)
lawlorsd84's Avatar
thanks for the info!
Old 08-27-2008, 11:44 PM   #12 (permalink)
2141pete's Avatar
I got the rims today, tires will be here in the morning.
