Old 08-15-2008, 12:16 AM   #1 (permalink)
Bigger front than back on a dually?
Would it be possible to run a bigger tire up front on dually width wise than on the back? I think someone said you can run a 255/85/R16 on the rear without needing a spacer, and i did the conversion and that comes out to be a 33x10" tire (give or take a minor amount). Now could you run a 33 by say 12.5" in front with those? or would it not work or just look stupid? I'm kinda trying to avoid having tires that stick out absurd amounts on the rear fenders but still be decently tall tires
pikeman16 is offline   Reply With Quote
Old 08-15-2008, 09:41 AM   #2 (permalink)
Super Administrator
BBRam's Avatar
I don't see a problem as long as the tires are the same height, otherwise it will mess with the gear ratios if a 4X4.
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 08-15-2008, 10:02 AM   #3 (permalink)
Buck08's Avatar
As long as diameters are the same.
07 silver Mega cab 5.9 6 sp smarty, SB 3600 DD and some other stuff:
95 2500 2wd project
Buck08 is offline   Reply With Quote
Old 08-15-2008, 10:26 AM   #4 (permalink)
i knew the height had to be the same just wasn't sure if the diameter being different would screw with it. whats the biggest tire they make in a 10 or 10.5" width?
Old 08-24-2008, 07:58 PM   #5 (permalink)
deepstep's Avatar
are your wheels all 6"? or are you widening the fronts?
deepstep is offline   Reply With Quote
Old 08-24-2008, 08:50 PM   #6 (permalink)
black01qcsb's Avatar
i think it would be cool. it would be like a cement truck
black 2001 2wd qcsb goerend billet,4.10's, juice with attitude, 5in fbd turbo back, black h2's 295/70/17 terra grap's 12k hid's 15.0 @91mph
black01qcsb is offline   Reply With Quote
Old 08-24-2008, 09:20 PM   #7 (permalink)
ynots57's Avatar
a question i would ask is:
would running different size tires mess with the ABS?
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 08-25-2008, 02:59 AM   #8 (permalink)
04SSHD's Avatar
if it's 2wd there should be no problem, if it's 4x4 your OD needs to match front and back
07.5 Dodge Ram 3500HD SLT 6.7L,11/06 build,5/08 delivery,PMT,DPF & EGR fell off,G56,4.10 (3.73 soon),C&C,HBS,5000k HID Solutions lights & fogs,14,000 miles to date,35" M/T,22.5's soon,Dyno at 445hp/907tq
04SSHD is offline   Reply With Quote
