Old 08-09-2008, 10:36 PM   #1 (permalink)
letumwork's Avatar
Toyo Open Country M/T+tire pressure
Just purchased some Lt295/70r/17 Toyo M/T's and was wondering what pressure you guys are running these at empty. I have the TPMS system so unless I wan't to look at a warning light I'm limited to 60psi min in the front and 45psi min in the rear(unloaded). The tires are rated at 3970 at 80psi which is higher than the stockers which were rated at 3195@80psi. I'm looking for the pressure that will give the best wear, mileage and comfort on the street in that order. Anyone with these tires find the magic number? Thanks!
2008, 6.7 Cummins, 4x4, Bighorn, Quad Cab, 6spd Auto, LB, Patriot Blue, Stock.
letumwork is offline   Reply With Quote
Old 08-09-2008, 10:47 PM   #2 (permalink)
You Can Take Your Vehicle Back To The Dealership And Have The Tpms Sensors Flashed To The Air Pressure You Are Currently Running... I Would Recommend At Least 55 Pounds All The Way Around And Rotation Every 5000 Miles.. Cross The Fronts To The Rear And Move The Rears Straight Forward.. You Should At Least Get Around 55k To 60k Out Of These...
2006 DODGE MEGA CAB W/ 10" OF LIFT, 38-1550-20 TOYO M/T'S, ATS ARC FLOW, SMARTY TNT, EDGE EZ, 5" EXHAUST W 7" TIP, RELENTLESS TSUNAMI FUEL SYSTEM, RELENTLESS BUILT TRANNY, MPI RACE TWINS, DRAGON SLAYER CP3, HEATER GRID DELETE, DDP STAGE THREE INJECTORS.
DSTIMMELL is offline   Reply With Quote
Old 08-09-2008, 11:15 PM   #3 (permalink)
I was at 43K miles with the least tread depth measuring 9/32ths. They all were between 9-11/32th.
That was at 35psi and rotated them once. Just did doughnuts to keep them even after that.
2008 Megacab 6.7L CTD. TDK Pre-Runner winch bumper with Warn 12K and 3pr of PIAA's. Kore Leveling kit. 18" Rockstars and 35" Toyo M/T's. 15.4" Drop Down DVD player for the kid. Wishlist: Pocket Flairs. NRA Life Member
JBuck is offline   Reply With Quote
