Old 05-29-2008, 07:33 PM   #1 (permalink)
1995 2500 can this be switched to duals??
I have a 95 2500 4x4
turbo desil
i beieve 8800 pound gvw axle setup
not the 7800
my stahl body on the back is rusted completly apart
If i could put dual wheels in the back
easily
I would like to switch to a 6 whl dump body
I use the truck mostly for junk yard runs and towing the ocasional bobcat
my record is 4700 lbs in the bed but she isnt happy. when loaded like that
With the dual whls it would be safer to drive loaded
Thanks guys for the help.. I love the site
Walker2230 is offline   Reply With Quote
Old 05-31-2008, 07:31 PM   #2 (permalink)
Robertb6963's Avatar
I would think so. Prolly more to it than just a dual conversion kit. I'm not sure, so lets bump it to the top.
-SOLD- 2000 Dodge 3500 DRW Quad Cab 4x4 @167k miles, 5 speed, patriot blue, Ranch-hand front/back, lift with BFG M/T, straight 4" pipe w/ 5" chrome tip, cracked block/head. I hate the 53 Block!!!
Robertb6963 is offline   Reply With Quote
Old 05-31-2008, 07:42 PM   #3 (permalink)
IDAHO CHAPTER VP
Teen wolf's Avatar
front spacers,rear spacers,tires and wheels bedside bumps with fender stiffiners, current to side markers, if equipped, current to tailgate third light,newer models,and im sure something else......its easy if mech. inclined and have parts truck. ohh ya the overloads that come on 3500 duelly.
06 black mega 4x Dave's Billet auto shiftenhansed D preditor tuff 5" 37's B special fooler riderites custom airbag muff delete redline catylist, Commander , AR-15..etc...."True Outlaws can survive"
Teen wolf is offline   Reply With Quote
Old 05-31-2008, 07:45 PM   #4 (permalink)
JeepinOverU's Avatar
97 12v 2500 4x4 NV4500, bashed in driver side cab, 4" exhaust, #100 fuel plate, gutted afc, valair kevlar/ceramic clutch, boost elbow, gauges, arp studs, ported head, 4k gov, twins soon.
JeepinOverU is offline   Reply With Quote
Old 06-01-2008, 03:06 AM   #5 (permalink)
D Gandy's Avatar
turbo desil
not the 7800
easily
If u are refering to switching to a 1-ton chasis dump bed(like a regular dump truck, only smaller), U should only need to put the dual wheels on your stock rear axle. Would be like a stock cab & chasis setup without the bud wheels in the front. Get a set of overload springs and u would be set.
Now if u mean to keep some sort of stock type bed setup with a dump, u would need the spacers on the back to help clear the bed and inner dual tire. Since u are only using this thing for a junk yard hauler, u shouldn't need to swap in the spacers for the front to run bud wheels unless u want it to look stock like a dually.
2006 2500 4x4 auto 4-door,straight pipe, airaid intake, predator/powerpuck,boost fooler,Autometer boost,tranny,EGT gauges with A-pillar pod,Banks High Ram elbow,Winspeed heater grid delete,35x12.5x20 mud grappler, Kore Chase 2.0
D Gandy is offline   Reply With Quote
