Old 04-10-2008, 10:28 PM   #1 (permalink)
Banned
19.5 or 22.5...
I am really tired of buying tires for my truck. I have looked into 19.5 and 22.5 rims to start running commercial. I would like the truck to sit up a little taller, but not so tall that i cant pull my Gooseneck Horsetrailer. Does anyone have experience with this?
HoofPower is offline   Reply With Quote
Old 04-11-2008, 10:58 AM   #2 (permalink)
Super Administrator
BBRam's Avatar
Bump...............
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 04-12-2008, 01:26 PM   #3 (permalink)
Performance's Avatar
I don't know about the 19.5s, but I know of guys using the 22.5s to pull gooseneck trailers. I have yet to find a gooseneck locally with the ball mount tall enough for me though. Also the tires are so big, that you will have to do a little trimming on the inside rear fenders to gain a little clearence if you do the 22.5s and a gooseneck, but it's nothing major and it's only an issue with a lot of weight on the trailer. I guess it really depends on your gooseneck height and how much adjustment you have left in the ball mount too.
I will say I love my setup and would do it again. The setup raised my truck 3" total not counting the leveling kit in the front. Every truck is different. The setup may not raise your truck the same as mine and you may not have to trim anything.
Hummmm, I don't know if I helped or not.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Classic Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
Old 04-19-2008, 01:26 AM   #4 (permalink)
84rzv500r's Avatar
Ive got 6 Alcoas in 19.5x7.50 with 245/70R19.5 Cooper Roadmasters and they look like they were made for the truck. A bolt on affair.
I added some ATS front flares to balance out the mega cab DRW fenders
I regularly pull in the 17000 to 22000 CGVW range...
Bigger and I send the L9000 with the 318 Detroit/RTO 9513 and tandem 38000 Eatons
2006 Megacab 6 speed DRW White, Alcoa 19.5 x 7.50 245/70R19.5 LRG Cooper Roadmaster Ribs, Katskinz Leather, Dynatrack Lockouts, DiProcol, ATS Front Flares, Muffler Eliminator...1973 Ford L9000 318 Detroit (8V-71) RTO-9513, wet line, tandem 38k Eatons...
84rzv500r is offline   Reply With Quote
Old 04-19-2008, 01:50 AM   #5 (permalink)
I just went through this....
It will be lots cheaper to do the 19.5s. You can get a set of the Eagle dually alloys for a grand. Throw in another 1.5k for tires and you are done. It will not drop the rpms by much, so no savings in fuel. The 22.5s will drop the rpms because the tires are about 6 inches taller in diameter. Good luck, Scott
cscott67 is offline   Reply With Quote
Old 04-20-2008, 02:03 PM   #6 (permalink)
With the 22.5s you will see a slight drop in rpms which leads to a slight increase in mpgs. With the straight drive trans you won't notice the rpm drop at all until you get in high gear. The 19.5s are cheaper, but the 22.5s look so much better. My personal opinion it was worth the extra money to get the look too.
Old 04-20-2008, 07:13 PM   #7 (permalink)
Talking
19.5 cheaper hands down the winner if price is a consideration but both of them are pretty dang expensive thumbsup:thumbsup
bigdieseldan ,:thumbsup
1997 12 valve,banks powerpack,banks twinram intake manifold,afe stage 2 air filter with torque tube,,ats stage 5 racing transmission billet
bigdieseldan is offline   Reply With Quote
Old 04-20-2008, 10:02 PM   #8 (permalink)
Lawn & Landscape pro
piersonslawnservice's Avatar
where can you get (6)19.5 eagle alloy rims for a grand? Im looking
piersonslawnservice is offline   Reply With Quote
Old 04-20-2008, 10:12 PM   #9 (permalink)
Yea good question.
Sparks280zt is offline   Reply With Quote
Old 04-20-2008, 10:17 PM   #10 (permalink)
7492's Avatar
Are you trying to tell me these are cheaper to run rather than what belongs on the truck, or are you trying to change tires less times. You are going to have to prove to me it is the first. If so, I would really think about a larger, proper sized truck , witch is going to be much safer.
07 Megacab 2500 4x4 6.7Liter 68RFE 3.70 limited slip . Bone stock and no problems 20 MPG highway easy .. 21.75 best so far.1999 Durango 5.9 Liter 3.92's ALL the options.
Work truck 09 Freightliner M2 33k GVW ISC 260/840 RFO9210B
7492 is offline   Reply With Quote
Old 04-21-2008, 02:00 PM   #11 (permalink)
These conversions are very safe. The idea is to buy tires less often and with the 150,000 mile rated commercial tires, you will get just that. Mine will dry rot before I get all the use out of them.:thumbsup
Old 04-22-2008, 11:11 AM   #12 (permalink)
There are several on e-bay......
And the bids are started under 900! Good luck guys! Scott:thumbsup
