Old 04-08-2008, 03:51 PM   #1 (permalink)
CanfieldOO7's Avatar
New Tires Question
So my Current Dayton Timberline M/Ts 33" are starting to run low and i was thinking if i should just go with those again or if i should upgrade to something better like some SSR Super Swamper TSLs. After reading alot of reviews they seem to be about equal in evry category except for mud, in which case the SSRs excel. So should i go for the SSRs or the Timberline/Destinations?
I also recently found out that my truck doesnt have a leveling kit like a thought it did, so if i were to buy that could i go up to 35" without the need for any spacers and would it hurt my MPG because i believe i have 3.73(or is it 3.83?) gearing. My truck also has the HD package so without actually measuring it seems like its slightly taller than other 12v Cummins when i look at them side by side.
Thanks in advance.
'96 Ram 2500 Cummins 12v, BHAF, #0 Fuel Plate, No Torque Plate, Modded AFC, 4x4, Heavy Duty Package, 33' Dayton Timberline M/Ts on Eagle alloys
318k strong and Counting
CanfieldOO7 is offline   Reply With Quote
Old 04-08-2008, 03:56 PM   #2 (permalink)
tclappcummins's Avatar
the big question is do you do a lot of off roading? do you like a loud humming tire???? more then likely you have the 3.73 and if you go with a 35 you are more then likely rub like CRAZY i dunno is this on stock rims or aftermarket rims?
Travis 06 2500 Megacab 4x4 gets a bath twice a week
tclappcummins is offline   Reply With Quote
Old 04-08-2008, 04:10 PM   #3 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
Check out the Cooper Discoverer STT for another good mud tire idea.
-Chuck
Proud Cummins Forum Sponsor since 2006
Specializing in AMSOIL everything
Change your thinking, not your oil.
Duluth Diesel is online now   Reply With Quote
Old 04-08-2008, 04:18 PM   #4 (permalink)
sry just saw the eagle rims disregard that part of my post
Old 04-08-2008, 04:28 PM   #5 (permalink)
scottd53's Avatar
SSR swamper is a pretty quite tire for a swamper. i have had the TSL Radials on 3 of the 4 trucks i have owned and they didnt humm at all going down the road. when my STT's wear out im getting swampers for the dodge. just watch for load ratings.
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight to black 6in turn-outs, 6in AMSOIL filter , 7in lift w/ 38x15.5 Baja Claws, Autometer Gauges... EGT,Boost,Fuel Pressure,Tranny Temp
scottd53 is offline   Reply With Quote
Old 04-08-2008, 04:28 PM   #6 (permalink)
I do as much offroading as i can and i dont mind if a tire hums or not because my current ones do that anyhow. Is the lower the letter the less strain you can put on the tires? E.g. a D can carry more than an E or is it opposite?
Old 04-08-2008, 10:20 PM   #7 (permalink)
PuffPuffPass's Avatar
Check out Toyo Open Country MT's.
If you have your heart set on an Interco SSR or Firestone, I'd go with the SSR. A friend of mine runs 37" SSR's on his Stupid Duty, which is a daily driver. He puts a lot of miles on them and they seem to last him about two years. He also rotates them quite often.
What you want to look for is 10ply, 3ply sidewall, Load Range "E"... I also look for a minimum of 3640lbs carrying capacity per tire. Load range "D" is a lower rated tire than an "E".:thumbsup
Read the specs for what ever tire you choose. There is always fine print.
'04 3500 :: KORE coils :: DUNKS arms :: THUREN trackbar :: DEFIANT steering brace :: TOYO m/t :: K&N filters ::
PuffPuffPass is offline   Reply With Quote
Old 04-09-2008, 12:15 PM   #8 (permalink)
Thanks, and my current tires are D rated so im not to worried if its not an E rating. Although that would be a nice extra.
Old 04-09-2008, 12:26 PM   #9 (permalink)
surfram's Avatar
-Chuck
How many miles do you expect to get out of your Cooper STTs?
2004 2500 SLT SWB 4x4,305/555, in-tank lift pump, 48RE, 3.73, westin cps step bars, magnaflow pro 4" TB, 305/65/17 BFG AT KOs,Timbrens, Leer Cap, Firestick CB antenna mounts, Wilson Silverload 5' antenna, Uniden PC78LTW CB
surfram is offline   Reply With Quote
Old 04-09-2008, 02:35 PM   #10 (permalink)
I used to say the same thing...D rated tires will sqirm around under the weight of a Cummins. They will wear out much faster, and are worthless if you plan to tow or haul a heavy load..
Anyway, just trying to save you the grief, and setbacks that I learned the hard way.
Old 04-11-2008, 12:09 PM   #11 (permalink)
Gixxer_750's Avatar
check out the trxus m/t...quite tire and more than holds its own offroad...and if you were wondering, the SSR is leaps and bounds above the firestone when it comes to leaving the pavement...it also has siping, which the firestone does not and that will make a world of difference in the ice or rain.
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..."
Powered by FBD
Gixxer_750 is offline   Reply With Quote
Old 04-11-2008, 12:34 PM   #12 (permalink)
Supporting Vendor
I should get 40k easy, and a I beat them pretty good. Coopers have always held up well for me. I've owned many Coopers on many different trucks.
