Old 04-07-2008, 09:03 PM   #1 (permalink)
Oilfield Trash
HarleyMedic's Avatar
What size tire.
Runnin 265/75r17e now. What is the biggest I can run without dooing a lift or leveling kit? Limited on tire selection also due to the fact that i pull a 39ft 16k toy hauler with 3k pin weight.
2006 F-350 SRW King Ranch. SCT, Magnaflow.
HarleyMedic is offline   Reply With Quote
Old 04-07-2008, 09:10 PM   #2 (permalink)
TORK-STIK's Avatar
tyres
you could use a 305/65/17 in an "e" load range and have no problems, that is what I run, or possibly the 315's at the most, but check the load range...........
2007.5 6.7L some bad parts fell off and some good parts are on, thanks to Walley at FTE Diesel. S&B H&S BFG FLO-PRO AMSOIL EDGE RECON GENOS GARAGE TRUXEDO FABIC ECLIPSE TINTING FASTCANUCK and ROLLIN COAL
TORK-STIK is offline   Reply With Quote
Old 04-07-2008, 09:22 PM   #3 (permalink)
Bomaster238's Avatar
i wouldnt go over a 305. with a leveling kit not over 315
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline   Reply With Quote
Old 04-07-2008, 10:15 PM   #4 (permalink)
PuffPuffPass's Avatar
Toyo makes an All Terrain tire at 34X11.5X17 that is load "E", 10ply, and rated at 3970lbs per tire. It will fit on a stock truck without issues.
You could also look at running some 19.5 wheels, and some really high load range tires if you drive a lot on the highway. They are a bit expensive, but would last you a very long time, especially if you tow alot!
'04 3500 :: KORE coils :: DUNKS arms :: THUREN trackbar :: DEFIANT steering brace :: TOYO m/t :: K&N filters ::
PuffPuffPass is offline   Reply With Quote
Old 04-07-2008, 10:37 PM   #5 (permalink)
hump's Avatar
Toyo's
Toyo makes an all terrain tire in size 285/75/17 (34x11.5) that would fit very nicely on a stock truck plus gives nice weight ratio since it is E rated.
I am running them & I got to say they are a very nice A/T tire.:thumbsup
03 short bed, 6-speed, 17x9 Helo Maxx 8's with Toyo 285/75/17, Smarty Beta, DiabloSport Puck, Zilla boost fooler, Walbro 392 kit, 5" straight piped with 7" tip, custom torque tube and AEM Brute Force filter with silencer ring MIA, Power Wagon fender flares.
hump is offline   Reply With Quote
Old 04-07-2008, 11:48 PM   #6 (permalink)
285x75x17
Did you notice a difference in fuel mileage with the 285x75x17 vs stock?
blazer bay is offline   Reply With Quote
Old 04-08-2008, 12:01 AM   #7 (permalink)
niedhogg's Avatar
Do you have any pics of your tires? I want to do the same on my dually and need a reference to look at. I may need a small spacer in the rear, but I want to go up in size. Just ordered my new Dura Flap mudflaps and they should be here this week, so I have the width covered.
'07.5, 6.7L 3500HD 4x4 Megacab Dually, 6 Speed Auto, Line-X Spray-in Bedliner, Muffler MIA w/5" Stainless Tip
niedhogg is offline   Reply With Quote
Old 04-08-2008, 12:04 AM   #8 (permalink)
redneck sailor
cajun5.9ctd's Avatar
I am running 315s on mine.
No leveling kit, it is 4x4
2006 Dodge 2500 4X4
Voliant Cold Air Intake, Edge Juice w/Attitude, Banks Ram Intake Manifold , MBRP 4inch turbo back exhaust, and a set of air horns
cajun5.9ctd is offline   Reply With Quote
Old 04-09-2008, 05:06 PM   #9 (permalink)
hump's Avatar
Thumbs up blazer bay
If there is any difference in MPG, then it is so small that I haven't really noticed. I still average 20.3 MPG......
Old 04-09-2008, 05:10 PM   #10 (permalink)
hump's Avatar
niedhogg
Here is a back view.....
[IMG][/IMG]
A front shot.....
[IMG][/IMG]
An angle view....
[IMG][/IMG]
And from the entire side...
[IMG][/IMG]
Old 04-09-2008, 05:22 PM   #11 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
I agree. 305/65/17 unless you do a 2" leveling kit. My friend is running this size on his stock 2003 quad cab short bed. They fit, and look great, but that's as big as I'd cram on there without a lift. Toyo makes a tire in that size that retains the E rating / 10 ply. Many larger tires like this drop to a D rating / 8 ply. Keep an eye on that spec when shopping for tires, especially if you haul heavy loads.
-Chuck
Proud Cummins Forum Sponsor since 2006
Specializing in AMSOIL everything
Change your thinking, not your oil.
Duluth Diesel is offline   Reply With Quote
