Old 04-03-2008, 09:04 PM   #1 (permalink)
itr.#1446's Avatar
Will a 13.5 wide tire fit on a 9 inch wide wheel?
I picked up a set of 35x13.5r20 mickey thompson baja tires off a friend and was wondering if they will fit on my 20x9 inch wheels? Or would it be better to have a 10 inch wide wheel? Right now i have 275/60r20's on there that are pretty much brand new so if i need a wider wheel i already have these up for sale ill take better pics of them on the truck if anyone is interested(they are xd hoss wheels 20x9 with toyo open country a/t 275/60r20 tires). thanks
05 2500 fass cfm intake k&n kore recon lift ssi track bar and steering brace 20" hoss wheels with 35's m.t. baja a/t's smarty pod mp8 5 inch single stack II silver 62 ats manifold pyro boost rail pressure 13.7 at 102 with a 2.0 60ft
itr.#1446 is offline   Reply With Quote
Old 04-03-2008, 09:07 PM   #2 (permalink)
RNworkshop's Avatar
yes they will fit
01.5 3500 3.54 QC DRW Sport Leveled 2.5" 4" Straight Piped Raptor 150 w/ big line kit 90hp Power Puck stacked w/ inj. power puck AEM Brute Force w/ a kustom fuel tune
All Thanks to Wingless KUSTOMS
RNworkshop is offline   Reply With Quote
Old 04-03-2008, 09:24 PM   #3 (permalink)
itr.#1446's Avatar
i figured they would since i had a 12.5 on a 8 wide rim all i noticed was they balloon more and the centers wear down alittle faster, so i assume if i have a 10 inch it would be better.
Old 04-03-2008, 10:16 PM   #4 (permalink)
normally that means that you're running too much air in the tires, should have nothing to do with the width of the wheel. i'm still working on stepping up to bigger wheels and tires so i might be missing something.
'95 Ram 2500 CTD 4x4
5" GrandRock turboback- HTT manifold-#5 TST plate-TST AFC spring w/washer swap-KDP tabbed-Fluidampr
avshi750 is offline   Reply With Quote
Old 04-06-2008, 11:37 AM   #5 (permalink)
Take Your Chrome Home.
K5Cruz's Avatar
I run a 13.50 STT on a 9" Rockstar with no problems.
2007 6.7 2500 Crew Cab 6 Speed Manual. Black, Black Rockstars, Mud Grapplers, H&S 4", MBRP, PMT, AFE, Valair DD, AD150, MP-8. 458hp/941tq.
Chrome wont get you home and it only takes 13 months to get a Road Armor.
K5Cruz is offline   Reply With Quote
Old 04-07-2008, 03:39 AM   #6 (permalink)
itr.#1446's Avatar
Hey couple quick questions:
1 what is everyone running for tire pressure?
2 My tires run alittle on the bottom of the rear fender alittle at full lock if i change the caster will this push the axle forward alittle or enough to clear the fender more?
Old 04-07-2008, 03:41 AM   #7 (permalink)
jd_2001's Avatar
yes they will fit but you are better off with a ten.
2001 2500 white ext cab /edge comp /edge jammers/ 4" straight pipe.
jd_2001 is offline   Reply With Quote
Old 01-26-2009, 11:29 AM   #8 (permalink)
Hey guys im new here but yall seem like the guys i need to talk to. im looking to upgrade wheels and tires. will 33x12.50s on 17x10 wheels work without rubbing on a stock 05 2500? if not what leveling kit do yall suggest?
pickawaycountycummins is offline   Reply With Quote
Old 01-26-2009, 11:33 AM   #9 (permalink)
tclappcummins's Avatar
well that will depend on the backspacing of the rim.. but more then likely they will not rub... and welcome!
Travis 06 2500 Megacab 4x4 gets a bath twice a week
tclappcummins is offline   Reply With Quote
Old 01-27-2009, 04:47 PM   #10 (permalink)
mpikas's Avatar
from what I'm seeing they should fit if the backspacing is reasonable... what 17x10's do you have (it's not a common size)?
mpikas is offline   Reply With Quote
