junk yard 22.5 Need some insight - Dodge Cummins Diesel Forum
Old 02-15-2012, 07:14 PM   #1 (permalink)
xcountryguy04x's Avatar
I can get a set of steel 22.5 for $250. He said he had 2 styles. The ones that take the pilot stud on the duals or the ones that you slide both wheels on the studs and torque em down. I am wondering how the more common adapter is made. I am assuming the the 2nd style right? Also, are there diffent bolt spacings and center sizes?
98 Ram 3500 dually, 12v, QCLB, Flatbed, NV4500, Valair DD sintered Iron w/ 3850# PP, AFC is "tweaked", D-Tech 62/65/12 over S475, 5x.016 w/ .015'' lift, DDP 024 DV's, P-Pump flowed to 550+cc by DPE, 0 plate, 4k, 60lb springs, ARP 425's, Haisley push tubes
xcountryguy04x is offline   Reply With Quote
Old 02-15-2012, 07:27 PM   #2 (permalink)
there is two types of wheels, a hub pilot which only uses a stud with a nut to hold them on, that is the most common adaptor, the second type is a bud pilot wheel, where one wheel goes on and then you tighten it down is a nut/stud style bolt, and then the second wheel goes on and tightens down with a nut, i have not seen a adaptor made with that style lug
06 4x4 QCSB 6spd, EFI Live, S&B Intake, gauges, 5" exhaust. and a few other little things, brought to you by Aggieland Performance Diesel & Customs.
bagged93gmc is offline   Reply With Quote
Old 02-15-2012, 07:28 PM   #3 (permalink)
the best way to tell the difference between the two, hub pilot will have a hole for a stud to go in, the bud pilot wheel there the studs come through, the holes will have a beveled edge
Old 02-16-2012, 05:25 AM   #4 (permalink)
I gotcha. Thanks. What about bolt patterns and center size. Are they all the same or different for different trucks
Old 02-18-2012, 11:28 PM   #5 (permalink)
Performance's Avatar
There are two different lug patterns, a small and a large. I do not recommend using an all steel wheel setup. There is nothing to gain, but a ton of rotational mass. You will see a big difference in power and stopping. It's best to stick with at least four aluminum wheels and use only two steel wheels for inners. The steels are honestly just to heavy.
2006 DODGE RAM 3500 - Silver, Debadged, Reg. Cab, 4x4, Dually - EFI Live by Anarchy, CFM+ Intake, AEM HD Intake, MBRP 5" Exhaust, Fass HD 150, South Bend DD Clutch, Isspro Gauges, Air Horns, DDM 12,000K HIDs, ReadyLift Leveling Kit, 22.5" Alcoa Conversion
Performance is offline   Reply With Quote
Old 02-19-2012, 01:36 PM   #6 (permalink)
i agree with performance, you would be adding a ton of useless weight
Old 02-20-2012, 01:19 AM   #7 (permalink)
T.chasehill's Avatar
I am also looking into doing this conversion. How much of a lift do you have to put on your truck, spacers and things like that? And what kind of ride quality and weather performance can you expect with this setup?
05 dodge 3500 dually, Laramie package 4x4. Black, frontier front bumper replacement.
T.chasehill is offline   Reply With Quote
Old 03-17-2012, 05:45 PM   #8 (permalink)
Glad to Be Here
2012 RAM 3500's Avatar
bump......
2012 Ram 3500, G56, 4 x 4. Stock.
2012 RAM 3500 is offline   Reply With Quote
