Old 02-07-2008, 01:43 PM   #1 (permalink)
HELP FIGHT CA SMOG REGS!
dezl's Avatar
bolt pattern measurments
what is the measurments for an 05 2500?
thanks
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock.
69 Chevelle, BB 427, Ported and polished heads, Custom cam, 10.5/1 compression, Forged TRW pistons, 1.7 Roller rockers, Holley 750 double pumper, Stage 2 TH 400, 12 bolt rear end
dezl is offline   Reply With Quote
Old 02-07-2008, 01:47 PM   #2 (permalink)
Super Administrator
BBRam's Avatar
This may help.
http://www.cumminsforum.com/forum/te...terchange.html
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 02-07-2008, 05:35 PM   #3 (permalink)
dezl's Avatar
thats kinda confusing to me.....
Do ford f350 wheels fit an 05 dodge ? Is my real question.
Old 02-07-2008, 05:50 PM   #4 (permalink)
jitt08's Avatar
Location: lower central NY but in the sunshine state right now
I know chevs wheels are the same paterin as dodge as far as the 99 gos
99 3500 auto 2WD DRW mosty stock 5" straight pipe 100 raptor fuel pump silencer ring m.i.a.261k and counting http://myspace.com/jitt08 and my email is jitt08@myspace.com
jitt08 is offline   Reply With Quote
Old 02-07-2008, 06:00 PM   #5 (permalink)
Diesel Poser
slagburn's Avatar
Ford went to a metric bolt circle in 97 or 98 I think and Dodge stayed with a standard pattern - prior to 97 I believe they were all the same.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21
slagburn is offline   Reply With Quote
Old 02-07-2008, 06:04 PM   #6 (permalink)
Roid's Avatar
the 2005 should be a bolt pattern of 8x6.5 for the wheels, or 8x165.1metric
03 2500 SLT, HTS Billet Trans, Airdog 150, II CP3, +75HP Injectors, K&N CAI, 4" 409SS EXHT, Bully Dog TD, Flex-a-lite fans, 20x10 WCC dubs, 35s Nitto Trail Grapplers, Road Armor, 2' leveled.
Roid is offline   Reply With Quote
Old 02-07-2008, 06:05 PM   #7 (permalink)
TEXAS SOUTH CHAPTER VP
Jesparza300's Avatar
if the rims came off a ford from the year 97 and down they will fit, 97 and up will not fit
TEXAS COAL ROLLERS SOUTH VP
07.5 dodge ram 2500 4x4 6.7 diesel
K&N filter
68RFE 3.73 gears all stock for now
http://www.cumminsforum.com/forum/texas/
Jesparza300 is offline   Reply With Quote
Old 02-08-2008, 06:58 AM   #8 (permalink)
D Gandy's Avatar
The main difference through the years was differnt hub size, and this was only on stock wheels. Aftermarket wheels will have a common fits all hub size. All were 8x6.5" till the Ford Superduty came on the seen in 1999, they are all metric patter, not sure what the digits are. But to answer your question, no Ford 1999 and up 8-hole will only fit ford superduty's.
2006 2500 4x4 auto 4-door,straight pipe, airaid intake, predator/powerpuck,boost fooler,Autometer boost,tranny,EGT gauges with A-pillar pod,Banks High Ram elbow,Winspeed heater grid delete,35x12.5x20 mud grappler, Kore Chase 2.0
D Gandy is offline   Reply With Quote
Old 02-08-2008, 12:30 PM   #9 (permalink)
dezl's Avatar
thanks fellas
