Old 02-06-2008, 04:14 PM   #1 (permalink)
255/85/16 Tire discussion
I'm considering 255/85/16s for my 02 Quad Cab 4x4. I'd like to hear from anybody using this size. How does it drive? How is the gas mileage compared to stock? Theres not a lot of selection in this size but the BFG Mud Terrain looks nice and i can get a discount on them at work. I want this truck to be good at everything on road, off road, fuel economy, ect ect. Let the discussion begin!
dareo is offline   Reply With Quote
Old 02-09-2008, 07:28 PM   #2 (permalink)
ya i have a 01 dually with 255/85/16 bf mud terrains on it it rides the same as the stock size 235/85 tires due well in all weather if you have a dually they don't rub with they stock rims fuel milage stayed the same
duallyjuice is offline   Reply With Quote
Old 02-11-2008, 05:59 AM   #3 (permalink)
Duallyjuice, do you have any pictures of your truck with 255/85R16??
Best Regards Basti
GermanCummins is offline   Reply With Quote
Old 02-13-2008, 08:29 PM   #4 (permalink)
Yes please post a picture of your truck. My wife doesn't want "lerpy" tires but i think it'll do better for the MPG. Ours is not a dually, but a picture of the front end would be nice. If i could find a 265/85/16 that would be perfect.
2002 QC 4x4 Laramie 6MT bought with 32k miles Added a Smarty, FASS, and BFG MT 255/85/16s.
Old 02-13-2008, 08:31 PM   #5 (permalink)
bigblue24v's Avatar
thts gonna look way too small
you should be able to put atleast a 285 under there
thts my opinion..
and its for that reason im gettin ready to dish out for a 5" lift 35s n 20s
Old 02-14-2008, 12:58 AM   #6 (permalink)
New England Chapter VP
Actually, a 255/85-16 measures up taller then a 285/75-16, by about half an inch, they are just skinnier. I wanted the same tire but as far as i know there isn't any company that makes that tire in a E-rated 10 ply, which is my problem, as i have a dually. To run 285's on a dually you will need spacers whereas with a 255 you wouldn't need spacers.
Also, your mileage will depend on your gears somewhat also. 3.55's will be affected more by a taller tire then say, 4.10's like me, beucase 3.55 has a lower RPM already and the taller the tires the more then RPM will drop which is good for mpg, but the rolling mass of the tire takes more power to get rolling so you can get hurt by that in the long run. I noticed a slight increase in mpg when i switched from a 235/85-16 to a 285/75-16 because of my 4.10 gears, it brought my engine to a happier RPM on the highway. The truck was winding out too fast before and i needed to do something about it, if i had say a 315/75-16 or a 35'' tire it would start working in the opposite direction mpg-wise.
I hope you cna understand what im saying, its confusing
99 EC LB SRW(swapped from drw) 4x4 5spd/Valair 550 SD/4'' TB MBRP Duals W/Muff Delete/Adrenaline/S300G/Coaltrain 150s/ATS 3 Piece Manifold/Volant CAI/Custom 3'' SS Intake/Airdog 150/Re-Tourqued Studs/2'' Leveled/Bilstein 5100s/RareParts Adj. TrackBar/MaxxLinks Swaybar Endlinks
Special Thanks to Valair Clutch and Coaltrain Diesel
KeepItCrunk96ZJ is offline   Reply With Quote
Old 02-17-2008, 11:43 PM   #7 (permalink)
I do have 3.55 gears and nothing to tow (yet) and would like to get my 6th gear RPMs real low. Anybody know of a taller skinny tire other than the 255/85/16? I've got 16" and 17" dodge wheels to choose from. I looked into the 285/75/17 but Schwab's wants over 300 each for them and i think thats bs.
Also i'd still like to see some shots of a 2nd gen dodge wearing some 255/85/16s
Thanks!
Old 02-18-2008, 10:20 AM   #8 (permalink)
e-rok's Avatar
I would like to know also as I need to replace my stock 215's for something a little taller as I sit at 2300rpms on the highway going 75............
1995 3500 DRW Ext. Cab 2wd
e-rok is offline   Reply With Quote
Old 02-25-2008, 09:41 AM   #9 (permalink)
No pics huh? Thats okay, i went ahead and ordered a set of 255/85/16 BFG Mud terrains. Hopefully they come in today and i can post pics up soon!
Old 02-26-2008, 12:38 AM   #10 (permalink)
I put my 255/85/16s on today, and got my smarty. The ride is much smoother, a little louder, and i've got lower RPMs. it runs about 1850 rpms at 70mph, tire height adjusted via smarty. As for fuel economy, too soon to tell, but it seems good. The overhead will go up to 30mpg at 60 mph on level ground. Who knows if this is right or not. Smarty is only set on #1 fuel economy mode and its really impressive in the response and power. I'm quite happy even though i spent over $1400 today. Too dark for pics but i will get some soon!
