Old 02-03-2008, 03:49 PM   #1 (permalink)
2008 3500 duelly srw conversion help
Hello all new to site couldnt find through a search what im looking for..
Can i remove the outer duells and flip the inside one to make it closer to the fender or can i get a wider rim or a spacer for this truck thanks all...:thumbsup srw conversion
kanatuna97 is offline   Reply With Quote
Old 02-03-2008, 04:02 PM   #2 (permalink)
Banned
ur trying to make srw?????
ccoop769 is offline   Reply With Quote
Old 02-03-2008, 04:22 PM   #3 (permalink)
Oh yes thats what im looking to do ,thanks srw
Old 02-03-2008, 04:24 PM   #4 (permalink)
Banned
Why didnt you just buy a SRW truck???
Im sorry, have no idea on how to help!! Good luck
Old 02-03-2008, 04:30 PM   #5 (permalink)
Buck08's Avatar
The two rear wheels have the same backspacing. So if you take one of and flip the other it will look the same just with no inside wheel. Seen it done and it looks kinda weird. Could get a really wide single style wheel or get a super single big rig wheel and run wide tires.
07 silver Mega cab 5.9 6 sp smarty, SB 3600 DD and some other stuff:
95 2500 2wd project
Buck08 is offline   Reply With Quote
Old 02-03-2008, 04:38 PM   #6 (permalink)
Cheap,NOT Easy
Slimsss2's Avatar
YOU can do this,,I have "singled" one side many times to get home,,be sure the luggs are torqued.
The look is a bit strange (dorkie) with the dually fenders!!!
'08, 6.7 Blue-Tec Turbo/injected Cummins Diesel, 2500, SLT, Quad C, ES-6~spd-Auto, 4x4, 3:73's, (free) 1yr. Sirius radio,Factory Spare Tire Lock,TPMS,12V Cigar Lighter,12V Rear Slider, Ride-Rite Bags, B&W Turnover,....."The factory Jake(ex-brake) is great"...... '''They Call.............I Haul'''----
Slimsss2 is offline   Reply With Quote
Old 02-03-2008, 04:53 PM   #7 (permalink)
Thanks bought this truck for biz failed, so im stuck with this duelly as my daily driver and so i figured 2 wheels would mean better gas millege and less wear on the truck.
One tire shop told me if i flipped the tire and rim i would crack them would be unsafe just couldnt see this,some wide rim would really be the answer i guess ...
Old 02-03-2008, 06:24 PM   #8 (permalink)
Tranny shoppin'
paulm85's Avatar
Really you won't save yourself any mileage or wear on your truck if you only run one back tire on each side. The loss of mileage will be because of the bigger fenders and other things not because of the 4 rear tires, especially if they are aired up correctly. In my opinion just run with all the tires back there.
'05 silver 2500 CTD auto, laramie, 4x4, Just a simple farm truck....
Best 1/4 time:::: 14.22 @ 96.7mph with stock tranny
paulm85 is offline   Reply With Quote
Old 02-03-2008, 06:47 PM   #9 (permalink)
A good tire shop should be able to help if big singles are available, but buying then would cost you a lot more than running the duels. It would give you lots of extra wheels for tire rotation. Play safe
JP 3 :Licenced HD mechanic for 35 years. RETIRED! worked on engines all my life. Spent last 19 HAPPY years at Freightliner:
jpringle3@hotmail.com is offline   Reply With Quote
Old 02-03-2008, 10:50 PM   #10 (permalink)
Anyone want to buy a low kms truck lol 4000 kms
thanks all
Old 02-08-2008, 07:27 AM   #11 (permalink)
D Gandy's Avatar
The tire guy u talked to was an idiot
How would running and flipping 1 rear wheel be any different fron the front setup. IF it is turned in or out doesn't matter, the force is still being applied at the lugs and mating surface.
2006 2500 4x4 auto 4-door,straight pipe, airaid intake, predator/powerpuck,boost fooler,Autometer boost,tranny,EGT gauges with A-pillar pod,Banks High Ram elbow,Winspeed heater grid delete,35x12.5x20 mud grappler, Kore Chase 2.0
D Gandy is offline   Reply With Quote
Old 02-08-2008, 12:59 PM   #12 (permalink)
Performance's Avatar
You are not going to save anything much by just running single wheels. It's more trouble than it's worth, because the dual wheels don't hurt the truck in any way and you aren't going to gain any fuel mileage either with singles compared to duals.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Classic Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
