Old 01-30-2008, 01:24 PM   #1 (permalink)
Kraig's Avatar
Am I crazy or what?
Hey Guys-
Am I crazy to run 315s (35”) if I will be towing a fifth wheel around? I really, really, really want bigger tires but I don't want to throw everything off balance! Thanks
2006 2500 QC LB 4X4 6 Speed Manual: AFE Stage II Air Intake, CFM+ intake horn, Bullet, Jacobs Systems Exhaust Brake, Magnaflow Exhaust, n-Fab Nerf Steps, 2" Level, Toyo 295/70R17 MT's, Fold-a-Cover Tonnaeu, Amsoil BMK-21 Bypass system, and Mag-Hytec Diff Covers
Kraig is offline   Reply With Quote
Old 01-30-2008, 01:25 PM   #2 (permalink)
Bomaster238's Avatar
i dont think it would be too terrible....but if u are worried u could go with a 305/70 which is a 33
94 12valve 5 speed.5" single stack,AFE intake,Holset H1E, bosch 370s, TST #6, Schied Diesel DVs, HD valve springs, FASS150 A-meter Pyro and boost, boost elbow, KPD killed,16.5*, 550hp clutch on the way, leveling kit, 35s
Bomaster238 is offline   Reply With Quote
Old 01-30-2008, 01:30 PM   #3 (permalink)
Posting Suspended
depended on your 5th wheel I have a leveling kit and had 35" baja claws on it and towed the 5th around just fine, I only towed the 5th once but it was to more check on how my truck and my hitch would handle.... I pulled a 36' camp trailer around oregon a couple times and had the 35"s on no big deal... just would check and see if your trailor is a lowrider or does it sit pretty high..
GETERDID is offline   Reply With Quote
Old 01-30-2008, 01:52 PM   #4 (permalink)
HELP FIGHT CA SMOG REGS!
dezl's Avatar
i used to tow, not a fifth wheel but my truck had 40's on it....
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock.
69 Chevelle, BB 427, Ported and polished heads, Custom cam, 10.5/1 compression, Forged TRW pistons, 1.7 Roller rockers, Holley 750 double pumper, Stage 2 TH 400, 12 bolt rear end
dezl is offline   Reply With Quote
Old 01-30-2008, 02:27 PM   #5 (permalink)
Kraig's Avatar
Thanks Guys-
I wouldn't be worrying about it too much if were pulling a travel trailer because I can just drop the ball mount down accordingly. Unfortunately not so easy with the 5th. I have attached a picture of the rig and trailer with everything still stock. Whadya think, would raising the vehicle another 4 inches or so raise the front of trailer too high?
Old 01-30-2008, 03:41 PM   #6 (permalink)
Banned
DORKWEED's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
You're gonna have to modify your trailer. You ain't gonna have clearance Clarence with 35's!!! You've got a good looking set up judging from your picture. Personally, I wouldn't change a thing!!! What kind of suspension does the trailer have???? Larger tires for it??? Put axle under the leafs if so equipped??? Add box tubing between the torsion axles if so equipped??? Give us some more info.
DORKWEED is offline   Reply With Quote
Old 01-30-2008, 03:49 PM   #7 (permalink)
Posting Suspended
good thoughts ... you can allways raise the trailer a couple of inches to help out or mayber just a lil taller of a tire.... if you can lower your 5th hitch or your pin you could do that to.. I agree with maybe doing a block lift on your axles for the trailor is the leaf springs under or over your axle?
Old 01-30-2008, 03:50 PM   #8 (permalink)
Kraig's Avatar
The suspension on the trailer is leaf springs over axle. I guess it would be possible to raise it a little bit but would get a bit nervous that it would be getting too top heavy. Maybe I should resolve myself to 33’s and be done with it. Although I guess I could always hang on to the stockers and change them out if need be. Gosh I wish I could leave well enough alone!
Old 01-30-2008, 03:52 PM   #9 (permalink)
Kraig's Avatar
Any suggestions for a 305/70 all terrain?
Old 01-30-2008, 07:58 PM   #10 (permalink)
YamYZ250F's Avatar
i hear on leavin alone...its to hard to do so..i think youd be fine with 33's
2006 Dodge 2500 Quad Cab Long bed 4x4, Magnaflow Muffler, Cat is MIA, HM 4" intake, 2.5" HBS leveling kit, and 285 A/T's, Edge MM www.OhioCoalRollers.com
YamYZ250F is offline   Reply With Quote
Old 01-30-2008, 08:43 PM   #11 (permalink)
Kraig's Avatar
By the look of your signature you have a serious case of the "can't leave well enuff alones" Sounds like an awesome truck. And, yup I have pretty much decided anything bigger than a 33 is gonna cause me more trouble than it's worth Thanks for the suggestion.
Old 01-30-2008, 08:57 PM   #12 (permalink)
TORK-STIK's Avatar
Kraig, If You Want A Good All Terrain Tire Check Out Bfgoodrich All Terrain Ko's. I Just Put A Set Of 305/65/70 On My Truck. Looks Good No Rubbing Still Has An "e" Load Range And Were Not Too Pricey. They Are Also Only 1 Inch Taller Than Stock So There Won't Be A Huge Power Loss And The Speedo Would Only Be Slower By About 2 Mph, Your Dealer Can Fix This With The Scan Tool...
2007.5 6.7L some bad parts fell off and some good parts are on, thanks to Walley at FTE Diesel. S&B H&S BFG FLO-PRO AMSOIL EDGE RECON GENOS GARAGE TRUXEDO FABIC ECLIPSE TINTING FASTCANUCK and ROLLIN COAL
TORK-STIK is offline   Reply With Quote
