Old 10-03-2007, 10:23 AM   #1 (permalink)
jeepit's Avatar
265's 0r 285's
Looking at tires and I would like to hear from anyone that went to a 285 75 16. I have 265 75 16 now and I want to know if there was a noticeable power difference or mpg difference. I tow some so I don't want to lose alot of mpgs. I am looking at Michelins LTX AT2, GoodYear Silent Armour ( if they make a 285), or Toyo At.
Your thoughts please....
2002 Dodge 2500, 6 Speed, 3:55, LB, LSD, Red/Silver, Smarty, Vulcan Draw Straw, AirDog, Stage 1 AFE, 4" MBRP, Full guages, BHAF, Rancho RSX 9000, Line-x, Western Snowplow. Hoping for a Scotty II.
jeepit is offline   Reply With Quote
Old 10-14-2007, 09:28 PM   #2 (permalink)
jeepit's Avatar
Anyone care to reply?
Old 10-14-2007, 09:31 PM   #3 (permalink)
stinnett25's Avatar
The Michelins are supposed to be great tires. As far as a mpg loss, you will loose some, maybe up to 2 miles but your ride may be a little better with a bigger tire. Power decrease, not much to speak of. You may look into getting your speedo recalabrated with the 285's. It will be off a bit. Hope that helps.
stinnett25 is offline   Reply With Quote
Old 10-14-2007, 09:43 PM   #4 (permalink)
totalloser's Avatar
The factory speedo always reads high. Get the taller tires. I went to 315 75 r16 and mine's off, reads low. But when I ran 285s it was dead on. Because the speedo is off, the mpg #s will be off. It will look like you did better before, but the #s lied before. I think you will do about the same on mpg with those tires. Spreads out your shifts too. Unless you start in 2nd. It becomes tall to start in 2nd with the bigger tires. I run almost the same rig but a duallie. It's kind of like having a taller ratio. Which for long hauls lowers your rpm. Oh and I am 3.55/six speed.
totalloser is offline   Reply With Quote
