What is the best air pressue to run with stock tires on a 4x4
I am taking a long trip un-loaded with 2007 CTD 4x4, what would be the Best Ride and MPG combo on the tire air pressure? Right now I am running 54# F and 50# R
2007 Dodge Ram 4x4 2500 5.9 Laramie Quad Cab,Leather, Sat Radio, Cab Lights, Bed Liner, Bed Cover,Wheel Liners Tow Mirrors. Banks Monster Exhaust System,Air Box. |
#2 (permalink) |
i would like to know as well?
07 mega cab.. 4 X 4.. 5.9.. 6sp.. D-badged.. stg 2 with amsoil in it.. turbo back 5" aero turbine.. workhorse triple play/off.. puck/90 and a smoken rattlen smarty.... |
#3 (permalink) |
me too... i would guess the more air the less rolling resistance since you start to run up on the center of the tire... but what is to much... especially at the expense of the tire...
'98 12V, 4X4, AUTO, CUSTOM EDM CUT FUEL PLATE, 3K PIERS GSK KIT, 16 DEG TIMING, GUTTED AFC, 4'' TO 5'' TO 6'' GRAND ROCK SINGLE STACK, CUSTOM BOOST ELBOW, BHAF, AUTO METER GAUGES (B,T,P), SILENCER RING M.I.A., TABBED KDP, :THREAT:
#4 (permalink) |
I just called my Dealer and he suggested 55 # front and 50# rear unloaded.
#6 (permalink) |
#1 Thread Derailer
![]() Join Date: Jan 2006
There is a label inside of the driver's door with the manufacture suggested air pressure's.:thumbsup
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
#7 (permalink) |
Administrator
![]() Join Date: May 2007
I run 55 in the front and 50 in the rear unloaded. I think those are both 5 PSI what is on the label inside the door. Too much air will wear the center out on the tire in a hurry, not to mention ride like a milk wagon..
A wise man speaks when he has something to say. Fools speak when they have to say something. |
#8 (permalink) |
from our own cummins data base... http://www.cumminsdatabase.com/image...hart_ram4x.gif
1990 D250 rc/lb auto, straight pipe 1998 12v qc/sb 4x4 auto, exhaust housing, plate MIA 1994 rc/lb 4x4 5-speed 4.10 straight pipe n free mods (burnt to the ground) |
#9 (permalink) |
Mine says loaded 70 rear, 60 front, and unloaded 50 front and 40 rear. Thats whats on the sticler on the inside of the drivers side door.
2006 5.9 2500 Quad Cab 4x4 SWB, 48RE, Smarty Jr, Icebox with S & B, Straight Pipe with FTE resonator, dipricol optix guages, 2" HBS level Kit, 35x12.50 Toyo MT's, BD flex plate, Goerend triple disc converter, Goerend VB |
#10 (permalink) |
I run 60 in the front and 40 in the rears as recommended on the door jam of the drivers door it has 2 recommendations one for light load and one for heavy load. I still have the stock OEM tires on, and now have 60k on them will get most likely 70k out of them. I have a 2005 Quad cab Laramie with 5.9 CTD and a G56 4:10 and a Detroit Locker
#11 (permalink) |
My tires are rated at 80 # Max pressure. I run full pressure when I pull the trailer and 70F/ 65 R when it is just the 4-wheeler in the back. Weight of my truck is 7640 with 2 people and truck box in the back.
Mike ![]() 2001.5 2500 4x4 QC, Vulcan Fuel System with GDP Walbro pump. HTB2 62/13 SS, DDP 95 HP Injectors, HTT Pulse Manifold, Silicone boots and hoses, Comp, Smarty, BMK-11, 4090 Amsoil Air filter, Amsoil throughout. NRA Member. |
#12 (permalink) |
My Driver's Door Sticker 60# R 65# F with my stock tires but the dealerships says only if your carrying a load that I should run those PSIs.
