Old 11-02-2009, 09:57 PM   #1 (permalink)
Toyo MT air pressure
What are you guys running in your MT's? I just got a set of 35's and they put in 55 psi nitrogen, sound about right?
2006 5.9 2500 Quad Cab 4x4 SWB, 48RE, Smarty Jr, Icebox with S & B, Straight Pipe with FTE resonator, dipricol optix guages, 2" HBS level Kit, 35x12.50 Toyo MT's, BD flex plate, Goerend triple disc converter, Goerend VB
EquipmentUser is offline   Reply With Quote
Old 11-03-2009, 11:01 AM   #2 (permalink)
WyoMike6.7's Avatar
Yea, I would say that is about right. I need to check mine today, how is that nitrogen treating you? I wondered about doing that but air is a lot cheaper and business is slow right now.
2008 6.7 quad cab short box - Smarty - 5'' TBE RSD - EGR Blocked - Edge JWA (Used for Gauges) - Banks CAI w/scoop - Recon chrome ion cab lights - 2'' HBS leveling kit - Rolling Big Power R94 20x10 - Toyo Open Country MT 33x12.50 - Eyelids
WyoMike6.7 is offline   Reply With Quote
Old 11-03-2009, 08:32 PM   #3 (permalink)
Well I like it cause they threw it in for free and they said it wont leak out like air, one less thing to worry about checking. I think it helped mileage too cause I can't tell so far that I lost any going from 265's to 35's and I did recalibrate my speedometer but i've only had them on for a few days.
Old 11-03-2009, 09:08 PM   #4 (permalink)
you need to run the thing and feel the tread or use a heat gun and check across the tread... if you're higher temp in the middle, air down, if you're higher on the outside, air up.
it's going to depend on load, etc.
'06 Mega Cab 2500 4x4 auto. Smarty, built auto, etc.
'98 12v quad/long 2wd 5sp. studs, o-rings, FE, etc.
drunk on diesel is offline   Reply With Quote
Old 11-03-2009, 09:16 PM   #5 (permalink)
dodge*this's Avatar
I don't haul loads and I run around 50 in front and 35 or 40 in back.
dodge*this is offline   Reply With Quote
