Old 11-01-2009, 04:45 AM   #1 (permalink)
commonrailcummins's Avatar
Biggest Tires on stock suspension 2WD
I am wanting to get some new wheels and tires. I want to go with a 20'' rim and I was wondering what would be the biggest tire I could run without rubbing, or very minimal rubbing. I don't tow, or go off road. I have heard of some people going with 35's and having minimal rub and i would love to have 35's without putting a lift on my truck....
any suggestions and pictures would be awesome.
Thanks guys.
2003 2500 H.O. Full Billet Suncoast 48RE, Suncoast Billet Triple Disc Torque Converter, Lock-Up Switch, FASS 150/150 ,Banks Intercooler, Banks High-Ram, HTT Stainless Steel 62/71/13 Turbo, Bully Dog Power Pup (Soon to be SMARTY) 17X9 Eagle Alloy Series 101
commonrailcummins is offline   Reply With Quote
Old 11-01-2009, 09:03 AM   #2 (permalink)
cmcumminscowgirl's Avatar
i know you can fit 33s because i had them on my truck with stock suspension, depending on the wheel you choose i think you may be able to squeeze on a 35, from what ive been told it depends on the backspacing and offset of the wheel. if you have a wheel that sets further out of the wheel well and bigger tire will fit but also dont go more than like a 12.50 . . . im going thru the same thing right now and picking out wheels and tires for my truck which is stock height, but i found a leveling kit for about $100 and then definately a 35 will fit with no problem, hope i helped some
cmcumminscowgirl is offline   Reply With Quote
The Following User Says Thank You to cmcumminscowgirl For This Useful Post:
commonrailcummins (11-01-2009)
Old 11-01-2009, 03:12 PM   #3 (permalink)
I wonder what backspacing I would need to fit 35's, I don't mind if the tires stick out a little bit. Anybody have 35's on a stock suspension 2WD? Anybody have any pictures of their setup? Right now I am just looking for ideas, Feel free to post any tire size that is under a 35' because I dont want to go any bigger than that.
Thanks a lot.
