Old 10-29-2009, 10:35 AM   #1 (permalink)
skalve85's Avatar
2nd gen 35's level with 20x9 will they fit?
Ok, so I'm set on the Eagle 079, I bought them with 20x9 4.5 back spacing and -12mm offset. I'm also running a KORE 2 inch leveling kit and have control arms corrected to proper length aswell as track bar.
Now I'm looking at cooper stt but not sure if either set up will rub.
35x12.50r20
35x13.50r20
The prices between the two are only $100 bucks. I would rather have the wide look so the 13.50 would be in my favor but I'm not wanting to deal with destorying my tires on turns. Thanks for any info!
-Steve
99 Dodge 2500 4x4 191,000mi, 150hp FBD sticks, 62/71/14, ARP Studs @ 140ft lbs, FASS 150/150, Drag Comp, Suncoast tranny, ATS TripleLok, Diprocal Gauges, AirRaid Filter, Amsoil Bypass, BD Steering Brace, 4inch straight pipe, 35inch tires 1/4= 13.79
Ohio Coal Rollers
skalve85 is offline   Reply With Quote
Old 10-29-2009, 03:10 PM   #2 (permalink)
Kansas Chapter VP
You can fit the 12.50 with ease but the 13.50 will be VERY close. Hard to say on that one since everyones truck is a bit different.
2002 quad cab LB,24 valve CUMMINS,4x4 3.55 Dana 60F,70R
Kansas Cummins Crew ...Vice President
http://www.cumminsforum.com/forum/ka...mins-crew.html
Proud supporter of my RIGHT TO BEAR ARMS!!! Live by the 2nd......
Cummins in Kansas is offline   Reply With Quote
The Following User Says Thank You to Cummins in Kansas For This Useful Post:
skalve85 (10-30-2009)
Old 10-30-2009, 01:44 AM   #3 (permalink)
skalve85's Avatar
anyone else have any experiance before I order these tires?
Ohio Coal Rollers
Old 10-31-2009, 06:19 PM   #4 (permalink)
skalve85's Avatar
Well of course I did some more research and now thinking about the nitto trail grapplers, from what Im reading there a better version of the toyos! Im actually finding them cheaper then a set of cooper stt.
Nitto trail grapplers: $1225
Cooper STT: $1455
Ohio Coal Rollers
