Old 11-03-2009, 08:30 PM   #13 (permalink)
luky kid does your truck rub with 35's on 2inch leveling kit?
would they rub with bigger rims?
CSG0485 is offline   Reply With Quote
Old 11-03-2009, 10:48 PM   #14 (permalink)
lukkykidd's Avatar
All you guys with 37's do they rub? CSG0485 I don't think so. There is a ton of clearance. I bought a set of 20x9 wheels from les schwabs and they said that I wouldn't have any problem running 35's. Just watch the offset of the wheel.
lukkykidd is offline   Reply With Quote
Old 11-04-2009, 01:05 AM   #15 (permalink)
You'll be close, I had 35x12.50 on 8.5 wheels, can't remember offset exactly, but I was pretty close to the fender and front bumper on stock suspension, but never did rub without mud flaps. 37's on stock suspension, you might not rub driving straight, but other then that good luck LOL.
I just bought new 37x13.50 for my truck on 8.5 rims, 6" lift and they rub my control arms, VERY tight to my fender and front bumper. And if they were on stock rims like my old 37" they would hit the control arms even worse, but more bumper/fender clearance clearance.
Fair warning if you tow, haul etc make sure you get tires small enough they don't rub, you will want to hit yourself if your tires rub and you try to back up a trailer etc. Even in tight parking lots it is a downright pain. I am probably going up to 8" so I can clear the 37" properly.
2004.5 3500 Quad Cab 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline   Reply With Quote
Old 11-04-2009, 06:46 AM   #16 (permalink)
Always lost & Never found
NT2HLBLY's Avatar
37 13.50
2008-6.7-2500-go fast parts, 37s
1990-5.9-no fast parts... 37s
1991-YJ-go slow parts, 38s
1989-K1500 SBC soon to be on ROCKWELLS and 39.5s or bigger!
I do it on the rocks
NT2HLBLY is offline   Reply With Quote
Old 11-04-2009, 06:54 AM   #17 (permalink)
Pull It Till It Breaks!
Smourj21's Avatar
i think 35's look better than 37's it doesnt look as stuffed as the 37's
Leveled 2002 Short Bed Quad Cab 6 Speed SHO | MBRP 4" Duals | Short Shift | Valair DD | Edge A2 | BD HRVP44 | Airdog 150 | CFM+ | BD Steering Stabilizer | Brite Box| 3pc Exhaust Manifold | DDP 250HP sticks | 35" Toyo MT's on 18" Driiv Offroad |Bilstein 5100's| Dana 60/80 | 3:55's | Detroit TrueTrac | Traction Bars| HX40/S475 TWINS|
|520hp/1132tq With the 200's|
Smourj21 is offline   Reply With Quote
