Old 04-04-2007, 04:58 PM   #1 (permalink)
Tire size
Does anyone know what size tires you can run with lets say a 2 or 3 inch lift kit?
06 2500 CR QCLB 48re Silencer ring MIA, torque tube gutted
PSYCHOFREAK3 is offline   Reply With Quote
Old 04-04-2007, 05:00 PM   #2 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
35 or 36 anyway.
Proud Cummins Forum Sponsor since 2006 - SUPPORT YOUR CUMMINS FORUM SPONSORS, WE SUPPORT YOU!
Specializing in AMSOIL everything
Change your thinking, not your oil.
Duluth Diesel is offline   Reply With Quote
Old 04-04-2007, 05:09 PM   #3 (permalink)
Originally Posted by Duluth Diesel View Post
35 or 36 anyway.
YEP I have 3" lift with 33" tires lots of room left
Thanks Doug
doug1810 is offline   Reply With Quote
Old 04-04-2007, 05:13 PM   #4 (permalink)
MOPAR MAN's Avatar
if its a 4x4 35's fit well. My truck had a 2" leavling kit on it when i bought it with 35's
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper.
MOPAR MAN is offline   Reply With Quote
Old 04-04-2007, 05:34 PM   #5 (permalink)
Awesome thanks, I was thinking of going with like a 6 inch lift but that would require tires that are way too big lol. It is 4x4 but only 3.54 rear gears and I don't want to swap them out at all so 35's should be good there. Thanks again for the quick help.
Old 04-04-2007, 05:36 PM   #6 (permalink)
MOPAR MAN's Avatar
np any time. Im running a 7" lift with 3.55 gears and 37" tires. and the thing will still do 3rd gear roling burnouts lol
Old 04-04-2007, 06:39 PM   #7 (permalink)
Really hmmm... I might need to do some new research lol. I am still on the chevy gas lift requirements now I have to remember I am dodge diesel with TONS more power.
Old 04-04-2007, 06:45 PM   #8 (permalink)
MOPAR MAN's Avatar
one thing to keep in mind. my speedo reads about 10MPH slow and the odomiter to. it helps to know when checking your fule milige. with the 37's for every 100 miles on the odomiter / trip meater i have aculy gone 113 so the avrage mpg's on my overhead desplay is normaly 1.5-2.5 less than what i am really getting if it reads 18.5 i am really getting 20-21 mpg.
Old 04-04-2007, 06:47 PM   #9 (permalink)
MOPAR MAN's Avatar
at least thats what i have learnd so far with my truck. and checking my speedo and odomiter with a GPS.
Old 04-05-2007, 09:29 AM   #10 (permalink)
Diesel Addict
i would recommend the 35's due to you will save yourself some cash but for the look the 36's will do the trick...are you runnin aftermarket wheels or are you staying with the stock wheels?
Late Nights=04 Chevy LLY Reg Cab 2500HD,its lite and fast
Business Truck=06 GMC LBZ 2500 CC SB SRW,Custom Tuned
Weekend Warrior=1987 Chevy Silverado RC LB 2500,lifted with lots of extras
Economy Saver=02 VW Jetta TDI,Stock for now
TYREBOYZ_DEMAXIN is offline   Reply With Quote
Old 04-05-2007, 05:36 PM   #11 (permalink)
This would be my first lifted truck with big tires so I have no clue on the tires and rims. I guess at first I would want to stick with the stock rims for cheapness.
Old 04-05-2007, 05:41 PM   #12 (permalink)
MOPAR MAN's Avatar
It depends on the lift. Some lifts you may need more back spacing otherwise at full lock your tires may rub on the lower control arm but if you stick to 35's you should be fine. i needed to change my rims once i went up to a 37 for that reason.
