Old 10-20-2009, 09:54 PM   #1 (permalink)
OHIO CHAPTER PRESIDENT
Double J's Avatar
looking for Eagle 058 dually wheel pics
More specifically, these wheels with standard wheel used up front---not the dually wheel used in the front. I know I've seen a couple trucks run this set up, but can't find them. If you run this setup or know where to find a pic, please post it up. Thanks!
01 2500 SLT+, 4X4, AUTO, 3.55, 726RWHP /1216RWTQ, 11.55 @ 116
06 3500 SLT Big Horn, DRW, 4X4, G56,3.73,
OhioCoalRollers.com
Ohio Coal Rollers
Double J is offline   Reply With Quote
Old 10-20-2009, 10:14 PM   #2 (permalink)
MMeier's Avatar
Check out ...
www.DuallyWheels4u.com Not quite sure what you mean by the RWD wheel up front though ???? Clarify a bit more ?
03 QC 4WD dually, 6 speed, 3.73's, lots of extra goodies!! 551HP/1008 TQ @ MATS '07... 93 W250 5 speed, 3.54's, no longer stock ! Owner/ operator Double M Transport
MMeier is offline   Reply With Quote
Old 10-20-2009, 10:22 PM   #3 (permalink)
Double J's Avatar
The 058 series used in a single wheel application (3/4 ton). I've seen this used up front on a dually instead of the standard 058 dually wheel up front. It looked really nice and I just wanted to take another look at it before I make up my mind on wheels.
OhioCoalRollers.com
Ohio Coal Rollers
Old 10-20-2009, 10:26 PM   #4 (permalink)
MoPower05's Avatar
Is this what you mean?
2005 dodge 2500(driver),2005 dodge 3500 white flat bed(2.6 puller)
http://www.youtube.com/mopower08
www.afterhoursdiesel.com
MoPower05 is offline   Reply With Quote
Old 10-20-2009, 10:29 PM   #5 (permalink)
MoPower05's Avatar
This what your looking for?
Old 10-20-2009, 10:32 PM   #6 (permalink)
Double J's Avatar
Actually like this. Note how the standard 058 wheel used on a 2500 is used on the dually front---not the standard dually 058. I'm looking for a pic of a 3rd Gen with 17". I've seen one floating around somewhere, just can't find it.
OhioCoalRollers.com
Ohio Coal Rollers
Old 10-20-2009, 10:34 PM   #7 (permalink)
Double J's Avatar
Yes...there we go! Got any more angles?
OhioCoalRollers.com
Ohio Coal Rollers
Old 10-20-2009, 10:35 PM   #8 (permalink)
Look over on DTR on my old profile "Ramasaur"... my 03 had that set up and there's a few pictures from different angles.
06 4X4 Megacab, 48RE, Goerend Full Billet Race w/ DTT Shift Enhanser, Mag-Hytec DD Pan, Silver Bullet, ARP Studs,Smarty Beta 4.3/4.4, , Quad Boost Fooler, AFE Stage 2, Floor It Stage 2, GDP Comp w/ 2mk filter, & other stuff
Megaramasaur is offline   Reply With Quote
Old 10-20-2009, 10:36 PM   #9 (permalink)
MoPower05's Avatar
Also have these front wheels.
Old 10-20-2009, 10:42 PM   #10 (permalink)
Double J's Avatar
Do you remember what tire sizes you used? I may not be able to go that tall because they may interfere with my flaps.
OhioCoalRollers.com
Ohio Coal Rollers
Old 10-20-2009, 10:49 PM   #11 (permalink)
The MT Claws were 35X12.5R17 The earlier pics were 33X12.5's both with a 2" spacer between them.... damn I miss that dually......
Old 10-21-2009, 09:01 AM   #12 (permalink)
INDIANAFARMBOY's Avatar
Ill have mine soon and ill take some pics for ya. 058 front and rear 17x8 fronts with dually rears, it will look like Mopower 05. Mine is a reg cab long bed though
07.5-Reg. cab dually 4x4 - Big thanks to Fleece Performance Engineering
INDIANAFARMBOY is offline   Reply With Quote
