Old 10-21-2009, 09:50 AM   #13 (permalink)
slor1de's Avatar
Both my trucks 04 and 96 have eagle 17x6 rears and 17x8 fronts 33/12.50's on the 96 and 35/12.50's on the 04. Powdercoated black of course, not much of a fan of shiney stuff anymore.
[IMG][/IMG]
[IMG][/IMG]
96 ram 3500 4x4
04 3500 4x4
slor1de is offline   Reply With Quote
Old 10-21-2009, 05:45 PM   #14 (permalink)
OHIO CHAPTER PRESIDENT
Double J's Avatar
Looking good guys.
slor1de - what tire brand are you running on the 96? I'm eyeballing some M/T BAJA ATZ LT305/65R17 (33X12.50R17). Would these work both front and rear??
01 2500 SLT+, 4X4, AUTO, 3.55, 726RWHP /1216RWTQ, 11.55 @ 116
06 3500 SLT Big Horn, DRW, 4X4, G56,3.73,
OhioCoalRollers.com
Ohio Coal Rollers
Double J is offline   Reply With Quote
Old 10-21-2009, 10:34 PM   #15 (permalink)
slor1de's Avatar
Baja claws 33/12.50/17's
96 ram 3500 4x4
04 3500 4x4
Old 10-22-2009, 12:26 AM   #16 (permalink)
Iam also interested in doing the same thing down the road with my dually, Mopower05 your setup looks awsome with the 6 claws on there! What size wheels/tires and spacers are are you runnin?
1995 Dodge 3500 Dually Silver Regular Cab, Cummins, 5 Speed. 6 inch suspension lift , 3 inch body lift, 38.5 super swamper boggers wrapped around 16" eagle wheels, 6 inch stacks, #10 fuel plate, 4:10 gears. South Bend DD3600, Pyro and boost guage.
hairy05cmns is offline   Reply With Quote
Old 10-22-2009, 07:18 AM   #17 (permalink)
MoPower05's Avatar
Front wheels are 17X10 rear wheels are factory. Rear spacer is 1.75". Tires are 33-12.50-17 baja claws. But the pic shown is with out spacers.
2005 dodge 2500(driver),2005 dodge 3500 white flat bed(2.6 puller)
http://www.youtube.com/mopower08
www.afterhoursdiesel.com
MoPower05 is offline   Reply With Quote
Old 10-22-2009, 04:54 PM   #18 (permalink)
Super Administrator
BBRam's Avatar
Do the dually front spacers have to be replaced?
MoPower05, that looks Awesome!
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 10-22-2009, 05:13 PM   #19 (permalink)
slor1de's Avatar
Just unbolt the spacers
96 ram 3500 4x4
04 3500 4x4
The Following User Says Thank You to slor1de For This Useful Post:
BBRam (10-22-2009)
Old 10-22-2009, 07:53 PM   #20 (permalink)
INDIANAFARMBOY's Avatar
I'm runnin bfg 305/65r17 with 2 in spacer in back. Rims should b here fri and I can maybe get them on and some pics sat or sun
07.5-Reg. cab dually 4x4 - Big thanks to Fleece Performance Engineering
INDIANAFARMBOY is offline   Reply With Quote
Old 10-22-2009, 08:05 PM   #21 (permalink)
Poor Man Built
Dreadnaught's Avatar
you already have enough projects going on now old timer.
sweet looking trucks guys.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is offline   Reply With Quote
Old 10-22-2009, 08:19 PM   #22 (permalink)
Double J's Avatar
Very nice looking rigs. What other wheel manufactures offer the same style in dually and single wheel application? The Eagle Alloy 058 and KMC wheel Rockstars are the only two I've noticed so far.
OhioCoalRollers.com
Ohio Coal Rollers
Old 10-22-2009, 08:20 PM   #23 (permalink)
Diesel Junkie
Taquache's Avatar
subscribing
2007 FIAT 5.9L 2WD QC SB ELECTRIC BLUE Leather, Heated Seats, Sun Roof w/1st Republic of Texas Flag cover,BULLY DOG TRIPLE DOG Tinted Tailights {REMOVED: Intake Baffle, Silencer Ring, Badges, Kitty} <INSTALLED: Glass Pack, ICEBOX, 2" Drop Shackles, CFM+, custom stock grill, Dipricols, 6" Tip, GHD, Fiat Badging, AIR HORNS, custom interior, eyelids> 1/4: 15.2 @ 93.4 10-3-09 powered by Smarty
'80 Chevy Short Wide needs motor and trans. I'm long as an ant and tall as a snake
Taquache is offline   Reply With Quote
Old 10-22-2009, 09:30 PM   #24 (permalink)
MoPower05's Avatar
Originally Posted by MoPower05 View Post
This truck will be a dually in about 2 weeks. Wheels and tires already mounted, rear spacers here on Wednesday megacab fenders hanging in the garage.
