Old 03-26-2007, 10:18 PM   #1 (permalink)
Jay
Jay's Avatar
teflon wheels
I'm thinking about doing a teflon coated wheel by American racing. The Dominator wheel has a 4 1/2" backspace and the "new" Thug wheel has a 5 3/8" backspace. I realize that the factory spacing is 6", I wanted to know how much the offset played into this. Also I have 33" tires now and I will be moving to a 35" tire when these wear out.
I wanted to know which one you guys thought would be a better fit. I do a fair amount of highway driving.
Jay
2005 Quad Long Bed. 6 Speed, 3.73's, MBRP 409 no cat, AEM Workhorse intake with amsoil filter, 285/70 17 Toyo OC A/T on AR thug wheels, Isspro gauges, Quad X2, Smarty, Valair DD 3600#
Jay is offline   Reply With Quote
Old 03-27-2007, 12:35 AM   #2 (permalink)
btolenti's Avatar
If you only plan on leveling it, use the 5-3/8 backspace wheels. From what I have heard, if you run a 4.5 backspace wheel, you will have to run at least a 4" lift to prevent rubbing.
btolenti is offline   Reply With Quote
