Tires wearing funny
My front tires are wearing funny on the outer edges, kinda "scooping"? out. The center is wearing fine. Tire presure is at 55-60 on both. These tires have maybe 15k on them. I have not rotated them since i bought the truck in January when the tires were new. Do i need to rotate? or would my track bar wearing out cause this? Thanks for any advice
00' 2500 sport blacked out and debadged. Edge juice with attitude, AFE intake, 2" spacers, black steelies, 34" BFG at's, silencer gonzo, Edge jammer II's , Airdog 150, New VP44(stock) 5" straight RSD |
#2 (permalink) |
Time for a rotation. Probably should rotate between 5-7k miles for maximum tread life. MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2 |
#3 (permalink) |
rotation time. i rotate twice a year at least on all terrains and every season with mud terrains
02 2500 5.9 56Block 47RE MBRP 4" STR8 pipe w/ 5" tip, S&B CAI, ?silencer ring?, FASS 95/150, DDP 110s, Smarty, Edge Juice w/Att + HOT, NADP full race, SunCoast tc w/mag-hytec dd, NAPC HD tcase
#4 (permalink) |
ok thanks guys
#6 (permalink) |
underinflated? i thought 50-60 psi was about right for the steers ?
#7 (permalink) |
I've experienced the same problem with my BFG ATs. Outer 1" of the Front tires wears excessively fast. Rear wore fine, then I rotated them up front and destroyed the outer shoulder in about 6k. No amount of alignments or rotations solved this problem. rotations only mask it. One way I made mine last longer was halfway through the tread-life I had them remounted "inside out" so I could wear down what used to be the inside edge. The best explanation I got was that it was due to too much Positive Camber.
'07 2500 5.9L, S&B CAI, Muffler Delete, Line-x, 285/70/17 BFG ATs |
#8 (permalink) | |
Well sh!t thats not what i wanted to hear, well i guess i will rotate and check air psi and flip if i have to, looks like i'll be gettin new tires this spring
#9 (permalink) |
Are they D rated or E rated tires? That feathering on the outer edge is from too much tire flex. I keep my fronts at 65lbs+. A D rated tire will have more sidewall flex and the wear will be worse. D rated tires are border line not heavy enough.
2007 5.9 CTD Ram 2500 Quad Cab Short Bed, Bighorn Edition 4 Speed Auto |
#10 (permalink) |
Mine did the same thing. The toe was off.
07.5 6.7 Auto SRW SWB QC 4x4 White Lonestar Edition, leveled,B&W,S&B,DashHawk, and Smarty S-67 17PoD Thanks to RSD
#11 (permalink) |
My BGF's are doing the same, and I run 80 psi in front. guess too much caster is it. The problem is with the white walls rotating is expensive.
Will - I drive a DODGE, not a dam ram! 1946, 1949 & 1964 Dodge Power Wagons, 1953 Dodge M37, 2006 Dodge 3500 4x4 Megacab Edge and 5" FBD Exhaust |
#12 (permalink) |
Either feathering or cupping. Feathering is usually due to excessive toe-in (or out) Cupping is usually a worn suspension part (or really bad alignment). Here is a site with some good pics and input: HOW TO READ TIRE WEAR
06 Silver Quad Cab 4x4 Automatic -4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's -Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11 |
