Old 09-22-2009, 12:39 AM   #1 (permalink)
BlCoonrod's Avatar
Max tire size with 6"
I have a 6" Superlift rockrunner kit. I am currently running 36-15.50-18's on a 4.5" backspacing. Of course it never rubs.
I probably going to go with 37-13.50 Toyo's/
Or could I run a 38-13.50 with no rub?
Alabama Mud Machine is running 38-15.50's but said his rub when turning sharp. I also don't think I want to go with a 15.50 width this time as I only have a 9" wide wheel.
One last question, does the 37/38" Toyo's actually measure true or are they smaller?
BlCoonrod is offline   Reply With Quote
Old 09-22-2009, 01:21 AM   #2 (permalink)
07 MegaCummins
Skyd Ram's Avatar
Toyo's run very true to size. With your rockrunner links just make sure the are adjusted to position the front axle forward a little bit and you should be fine for 37's. The 38's will definitely rub.
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/RIZE/Lightforce
BMF Wheels/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
Addictive Desert Designs/S&B
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 09-22-2009, 11:11 PM   #3 (permalink)
BlCoonrod's Avatar
Anyone got any pics with 6" and 38-13.50's?
