Old 09-20-2009, 07:37 PM   #1 (permalink)
MadMav's Avatar
Will these tires fit my dually without spacers?
'08 Mega dually. Stockers were General 235/80/r17. Looking to put 265/70r17 Nitto D\Tera Grapplers on. Will they fit without spacers? Or if not, where and how big a spacer is needed? Thanks,
Mav
'08 Mega Cab Dually, 6.7, 6 speed auto, 27K miles and trouble free. MP-8 and S&B.
MadMav is offline   Reply With Quote
Old 09-20-2009, 08:41 PM   #2 (permalink)
slambin's Avatar
Mav
Been going round and round about this for over a month with my truck. Decided on 285/75/r17 went with 1 1/2 inch spacer. You will have to put spacer on them from what i have seen. I would suggest going with 1 1/2 inches because the 1/2 spacer doesnt leave enough room if you decide to pull bigger loads.
2009 Black Dually, Boss Hog Front Replacement, AirRaid Cold Air intake, 5 inch TBE, EGR Delete, Smarty 14ME, Edge Insight, 285/75/R17 Toyo M/Ts, 2 inch spacers
slambin is offline   Reply With Quote
Old 09-20-2009, 09:29 PM   #3 (permalink)
ram rod's Avatar
265 70 17 fit fine lots of room between tires on the back
RAM ROD 2006 1ton 4x4 dually, 2 inch leveled, eagle alloys ,superchips tuner, 4inch mbrp no muffler, cfm intake maifold, afe cold air intake,nfab 6 steps,line-x , make some smoke
ram rod is offline   Reply With Quote
Old 09-20-2009, 09:45 PM   #4 (permalink)
MadMav's Avatar
Uh OH....two different stories!
I occasionally haul my 40ft toy hauler and a couple other smaller trailers and I don't want them to rub. But the 265/70s are quite a bit cheaper than 235/80s. I won't be going any bigger and don't want to have to get a speedo corrector.
I guess I would like a couple more folks to say yeah or neah.
Mav
Old 09-20-2009, 11:43 PM   #5 (permalink)
Depends on which tire brand and tread you want to run.
I used to run 265/70R17 Toyo Open Country AT's on the '06 Dually I had and they had lots of room between them. I now have 285/75R17's on my '08 with a 1/4inch spacer and they just barely have a gap between them when at 80psi and hooked to the fifth wheel.
2008 Dodge 3500 Resistol Edition Megacab Dually 4x4, full load, CB, VHF Radio, Spray-in Boxliner, Soft Tonneau Cover, Mud Flaps.
porky69 is offline   Reply With Quote
Old 09-21-2009, 11:30 PM   #6 (permalink)
MadMav's Avatar
Looking at the Nitto Terra Grapplers or some Michelin's. From my research of here, it looks like there will be abou 1" between them at 80 psi. I'm thinking this will be fine.
Mav
