Old 09-19-2009, 10:33 PM   #1 (permalink)
Country Girl's Avatar
Do I need a lift with 35"'s?
I have a 2004 Dodge 1ton quad cab 4x4. Right now I have BFG All Terrain KO's 33". I would like to go up to a 35". My truck is stock, do I need to get a lift so they wont rub or will I be ok?
Thanks.
Country Girl is offline   Reply With Quote
Old 09-19-2009, 10:35 PM   #2 (permalink)
mjd91's Avatar
A leveling kit will clear them. Just watch the backspacing if you get new wheels.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels
mjd91 is offline   Reply With Quote
Old 09-19-2009, 10:37 PM   #3 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
You can fit 35's asking as you run the stock wheel/ backspacing.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 09-19-2009, 10:49 PM   #4 (permalink)
ok, thanks. The only thing I have done different is putting the molded mud flaps on the fronts. I do run stock rims 17"
Old 09-21-2009, 10:13 AM   #5 (permalink)
BillyRam's Avatar
Most folks run 35s with only a leveling kit and this looks about right. 37s are what most folks go for running lift kits. About the only problem you'll have running 35s on stock rims is rubbing the upper control arms at full lock. This is something that can avoided and most don't let it bother them much. Running a wider rim with a bit less offset will take care of this. Something like a 17x9 +18mm.
Billy
Garmon tranny SunCoast ProLoc
HTT ProStreet 66/71/13
652hp/1254tq=11.91/111.59-1/4
BillyRam is offline   Reply With Quote
Old 09-21-2009, 02:04 PM   #6 (permalink)
So, by putting 35" on am I going to end up with rock chips down the side of my truck? should I be putting flares on too? And if so, are the bolt on ones or the molded ones better? Thanks.
Old 09-21-2009, 03:12 PM   #7 (permalink)
BillyRam's Avatar
Flares are nice to have with wider than stock tires. Mud flaps aren't much good with 35s.
Billy
Old 09-21-2009, 11:24 PM   #8 (permalink)
slambin's Avatar
I know its hard to see. but this is my old truck with 35x12.50 toyo m/t. only rubbed slightly at full lock in 4wd. no lift at all
2009 Black Dually, Boss Hog Front Replacement, AirRaid Cold Air intake, 5 inch TBE, EGR Delete, Smarty 14ME, Edge Insight, 285/75/R17 Toyo M/Ts, 2 inch spacers
slambin is offline   Reply With Quote
Old 09-21-2009, 11:33 PM   #9 (permalink)
cummins159753's Avatar
well my 35's rub! bad lol. 4.5 lift coming next. i dont hit control arms, i hit the finder and inner finder
01.5 2500 QCSB 4x4 5spd. 16x10 mickey t's 35.12.50. 2in levelin kit. straight piped. quad xzt. bhaf. rapter 150. silencer ring mia. going diesel den!
cummins159753 is offline   Reply With Quote
Old 09-22-2009, 12:07 AM   #10 (permalink)
159753- I wonder if mine being a 3500 would be the difference?
Old 09-22-2009, 12:15 AM   #11 (permalink)
mjd91's Avatar
Im sure it's because the backspacing and width of his wheels.
Old 09-22-2009, 12:15 AM   #12 (permalink)
Poor Man Built
Dreadnaught's Avatar
your's being an 04 makes the difference. i run 315x70 r17 hankooks (just a tad under 35") and i don't have any rock chips just running the dodge molded mudflaps. i can hear the occasional rock ding off the doors, but it hasn't hurt anything yet.
it rubs the upper control arms if i'm going forward to the left or backward to the right. i know its weird, but the axle is shifted to the p/s about 1/2 an inch for some reason.
i don't run a leveling kit or lift kit either.
and by the way, hankooks are a nice tire. 10k on mine with minimal wear.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is online now   Reply With Quote
