Old 09-17-2009, 08:00 PM   #1 (permalink)
Tires
What's the largest tires I can fit with stock wheels,it's a dually and I'm planning on 2.5 hell bent level kit. But I don't want to put spacers on the rear wheels. Is there a minimum measurement between the rear tire's needed? Oh it's a 1995 4x4. Thanks for your help
pantera28 is offline   Reply With Quote
Old 09-17-2009, 11:35 PM   #2 (permalink)
THE BDR
ryans01's Avatar
IMO----anything bigger than 235/85r16s will rub...if you can get a set of newwer 7 hole 2nd gen wheels you can easily run 255/85r16 with no problem what so ever...now i know of a feller on here that's runn'n 35s on his....
Ryan S.
"The BDR Edition" 2001 4 X 4, 3500, 2nd NV4500, II SO VP, SBC DD 3600 12CB w/ input shaft AND Valair HD HYDRO'S, TSTPM3, Edge EZ, AFE, FASS HPFP, 5" turnout stacks, gauges 319.9/776.8 4/25/09 DUNBAR'S DYNO
ryans01 is offline   Reply With Quote
