Old 09-17-2009, 02:35 AM   #1 (permalink)
heyzipupyourfly's Avatar
tall lift tall tires and towing?
who does it? any thoughts?
Obv its not the most desireable setup if you are doing a lot of towing.
I'm still up in the air about a 6" LA and 37s OR a 2-4" on 35s. Ive been doing a tone of research, I know which lift and tires I would get and it all boils down to which direction to go in.
What i Tow:
-a Flatbed car hauler with a pretty lightwieght tube buggy(sometimes larger heavier vehicles) at least once a month I tow this, approx 100 miles
20' enclosed car hauler (occasionally gets moved but mostly not far or often.
ALL this While carrying an 8' truck bed camper loaded with a weekends worth of tools food and spare parts.
no 5th wheel trailers either
thanks for the input!
2005 quad cab longbed. Stock
heyzipupyourfly is offline   Reply With Quote
Old 09-17-2009, 02:47 AM   #2 (permalink)
poptarts's Avatar
shoot i would go with the 6 in and 37s. imo the 4 in and 35s looks not good. kinda stock
2006 dodge 3500 megacab LARAMIE 4X4. 9 in lift with bilsten shocks dual up front. alpine screen, kicker l7 12", 37 in toyo m/t with 22s. 4 dripol gauges,smarty sr,no silencer ring, cat, or muffler,dual 8 in tips.
poptarts is offline   Reply With Quote
Old 09-17-2009, 06:25 AM   #3 (permalink)
BillyRam's Avatar
Tall trucks raise the front of the trailer and throw the weight to the back. This combined with tall "D" rated tires can give you a dangerous amount of sway. Not to add you won't have much braking power on the truck with tall tires so better make sure the trailer has strong brakes.
Billy
Garmon tranny SunCoast ProLoc
HTT ProStreet 66/71/13
652hp/1254tq=11.91/111.59-1/4
BillyRam is offline   Reply With Quote
Old 09-17-2009, 06:49 AM   #4 (permalink)
smokee04's Avatar
i would would go with 35s my 8 inch lift with 37s sucks to slow down
04 clutch j&a II 62/65 fass
smokee04 is offline   Reply With Quote
Old 09-17-2009, 05:36 PM   #5 (permalink)
bldrinker's Avatar
Lift it as big as you want just re gear and get a nice drop hitch or custom make one. I know of a few guys with 14,000# fifth wheels on 40" tires, with powerjokes. No problem, just set it up right.
2006 2500 megacab 4x4 AFE stage 2, 4" banks exaust Edge EZ tuner
bldrinker is offline   Reply With Quote
Old 09-17-2009, 06:08 PM   #6 (permalink)
get vert's Avatar
I tow with mine just fine. I dont set the world on fire but I make it up the hills.
99 Dodge quad cab lb, 24v, ALL CUSTOM
get vert is offline   Reply With Quote
Old 09-17-2009, 06:14 PM   #7 (permalink)
haha i like the way you put that, "i don't set the world on fire"
I'm more or less worried about the trans being overworked and going on me. I believe my truck has 4:10s now, I still haven't had the time to jack it up and find out. so i "think" the gearing will be ok? maybe not.
either way i agree that 35s will look small it is a longbed 4 door. thanks for the input guys.
Old 09-18-2009, 12:17 AM   #8 (permalink)
bldrinker's Avatar
Re gearing will keep the tranny from working hard. The new gears probaly 4:56:1 will give the tranny mechanical advantage to over come the weight and "de gearing effect" of the tall tires. If you do go 35's stay with your 4:10's
Old 09-18-2009, 02:47 AM   #9 (permalink)
dodge24's Avatar
Since you said you would be hauling a slide in camper, I would tend to go with a little less lift than 6''. Of course this would be my personal preference and I have seen plenty of lifted rigs with campers, it just doesn't look like much fun having to fight all that sway around the corners, especialy while pulling a trailer! Air bags are a must either way, but you probably already knew that.
2001 Dodge Ram 2500 White Quad Cab, 4x4, Leveled with 35" BFG KM2s, BD Billet Converter Drag Comp, DDP 110's, HTT 62/65/13ss, HTT Quickspool Manifold
dodge24 is online now   Reply With Quote
