Old 09-06-2009, 09:59 AM   #1 (permalink)
Space Shuttle Door Gunner
Caleb S's Avatar
Help with tire size..widest 33 on 20x10???
Hey I could use some help. I am looking at buying a set of 20x10 wheels for my truck and I know I want to run BFG AT's in a 33. But I was wondering what is the widest size I can run on a 20x10 and not have rubbing issues. My truck does not have a lift or leveling kit...
Any info is appreciated. TIA
98 2500 4x4 5SP
Caleb S is offline   Reply With Quote
Old 09-06-2009, 05:44 PM   #2 (permalink)
SCRRRP
ruidosododge's Avatar
Caleb I believe it all depends on the offset of the wheel.. My bro's truck has 20x10's with a 305/55/20 and a leveling kit and it rubs when going in reverese and when its cranked the whole way. Not a lot but enough to notice.
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
ruidosododge is offline   Reply With Quote
Old 09-06-2009, 06:23 PM   #3 (permalink)
Caleb S's Avatar
Hey, thanks for the help man.
So what size tire do you recommend that I run on a 20x10 wheel with 4.5" backspacing ..
98 2500 4x4 5SP
Old 09-06-2009, 06:25 PM   #4 (permalink)
SCRRRP
No problem! Are you going to stay away from a leveling kit? What about rubbing?
Old 09-06-2009, 07:06 PM   #5 (permalink)
Caleb S's Avatar
Yeah I do not have a leveling kit right now...and would prefer not to put one on...
So I guess I need some input on this also.
Can you run 20x10s and 33's without rubbing?
98 2500 4x4 5SP
Old 09-06-2009, 07:42 PM   #6 (permalink)
TECH SPECIALIST
JWH_03_Dodge's Avatar
two of my friends with 2nd gens run 33x12.5x16.5 identical wheels, different tires. One had slight rubbing, the other didn't. We can try putting one of my wheels/tires on your truck at the jamboree. 4.5" BS 33x12.5x17s
John - 03 QC/LB 4x4 5sp
Visit the Hoosier Truck Club
FTE Diesel FASS giveaway Click here!!!
Originally Posted by Broke Down View Post
come on Steve....my nuts hurt and i am stuck on the couch
JWH_03_Dodge is offline   Reply With Quote
Old 09-07-2009, 10:28 AM   #7 (permalink)
Caleb S's Avatar
That might be an idea..Thanks John
98 2500 4x4 5SP
Old 09-07-2009, 04:31 PM   #8 (permalink)
TECH SPECIALIST
well, I pulled up the specs on my wheels, mine are only 17x9s, and its actually 4.75" BS, not 4.5" like i thought. I'll ask my friends if they remember the details on their's.
Old 09-07-2009, 06:55 PM   #9 (permalink)
fordassassin's Avatar
It all depends on tire. I had 20x12's with 305/55/20 and had rubbing because the Nitto Grapplers were squared and flat. Went to a 33x12.50x20 Toyo M/T and no more rubbing. Because the Toyo M/T was rounder on the side.
Try a 305/50/20. 32" tall with 12.8" wide.
Early 2004 that has a 120 speedo.Not doing anything Dodge didn't want
http://www.youtube.com/user/gooodyboyz559
fordassassin is offline   Reply With Quote
