Old 09-04-2009, 02:05 PM   #1 (permalink)
rodeoking34's Avatar
Will a leveling kit work for 35X12.50X18 on a 01 Cummins
i have stock tires on right now, but have 35X12.50X18. -12 offset tires and wheels, will they fit with just my leveling kit or do i need a lift?
rodeoking34 is offline   Reply With Quote
Old 09-04-2009, 05:37 PM   #2 (permalink)
Discount Tire Direct
Discount Tire Direct's Avatar
Test fit, make sure to turn the steering wheel to full lock. They'll probably bolt up just fine but as soon as you turn you'll have trouble. The stock tire is only 31.6" tall. With your aftermarket wheels, I'd guess you'd need about a 4" lift to get them to fit without too much effort.
Post up what you end up doing.
America's Largest Independenly owned Wheel and Tire Retailer
www.discounttire.com
Discount Tire Direct is offline   Reply With Quote
Old 09-27-2009, 07:31 PM   #3 (permalink)
I did put the 35X12.50X18 on my truck with just a leveling kit, and they do fit, a lil bit rub, i can deal with it.
2006 Dodge Mega Cab-4inch lift 35inch tires- Bully dog/tripledog(Crazy Larry)-South Bend clutch-5inch MBRP w/6''tip. Fass Fuel, 110 hP injectors, AFE stage II intake. Throttle Down Kustoms Front Bumper
Old 10-03-2009, 10:54 AM   #4 (permalink)
mwilliamsjr's Avatar
Two questions: 1. Where is your rub? 2.What wheels did you use? I'm have a rubbing problem and I think it's due to the offset of the Mazzi Hulk's. (see my signature for the setup) I'm trying to figure out WTF to do now! Thanks
2004 CTD 2500 4x4 quad cab, 6spd, 5" Rough Country lift, 355/65R18 Terra Grapplers on 18x10 chrome Mazzi Hulks, Smarty Jr., pop-up gooseneck, ... daily driver and kid hauler ...
mwilliamsjr is offline   Reply With Quote
Old 10-04-2009, 09:33 PM   #5 (permalink)
its rubs on the corner,of where the bottom of your door is. i have ultra-mamoth wheels. but you having a 5inch lift, you should not be rubbing. if you do, it is your offset!!! i had a 06 mega cab with my same wheels with a 4inch lift and didnt rub. hope i helped out.
Old 10-05-2009, 12:26 AM   #6 (permalink)
I had 35s on the 99 i used to have with the stock inside dually wheels, Eagle Alloy aluminum front and outside wheels, not sure on the backspacing, and a 2" leveling kit, and they didnt rub at all.
05 3500, NV5600 4x4, Edge Juice w/Attitude, K&N Air Intake, ATS exhaust manifold, CFM Intake Man.,Silverline 4" TBE, Silencer Ring MIA, Recon Smoked LED Cab/Fender Lights, 33" Firestone MT
backwoodsboy916 is offline   Reply With Quote
Old 10-05-2009, 09:58 PM   #7 (permalink)
i just put some 35's on my 00 with a 2.5" leveling kit, i ran around for a few days with it stock though. they rubbed the inner fenderwell when i hit a hard bump and barely rubbed the control arms. im running stock 04 17" steel wheels.
01 24v, 6spd, 4x4 Valair kevlar/ceramic, egt/boost/fp gauages, AD165, SO VP44, HBS 2.5", 35" hankook RT03's
andy99 is offline   Reply With Quote
