Old 09-02-2009, 02:07 PM   #1 (permalink)
Super10brss's Avatar
20 inch wheel offset...
I am thinking of going with a 20 inch wheel for my new truck... what off-set do I need.?.?.?... I do not want it to stick out too much.... but I also do not want to rub either..... I have seen +25...-25....-12..... Any ideas?.?.?.?. Pics would be greatly appreciated...
Super10brss is offline   Reply With Quote
Old 09-02-2009, 05:41 PM   #2 (permalink)
Scott183's Avatar
There are a lot of variables when asking this question. First question is, are you on stock suspension and what generation dodge do you own? Second is wheel width that the 20's are available in (9 fits comfortably). The third and most important thing is what size tires you will be running. Stock 3rd gen wheels are 17 X 8 w/ a 6.25 (approximately) backspacing and I beleive +42 offset. Please someone correct me on these numbers if I'm wrong. A 20X 9 will work with up to a 35" tire on a leveling kit only if you keep the backspacing under 5.5" which is around +6 offset. If you tell us details about your truck and suspension along with your preferred tire size we can guide you a little better.
'05 QC Short Bed, BLACK, 35" Toyo MT's, 4.10s, Line-X, Rough Country steps, KORE leveling kit, Superchips, MBRP Cool Duals, sounds by Alpine and JL
Scott183 is offline   Reply With Quote
Old 09-02-2009, 06:33 PM   #3 (permalink)
The King is back!
SkinInc69's Avatar
You will be safe with -12 offset. You will get more rubbing depending on lift with -25 offset. I have -51mm offset cause I like em wide.
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance BLACK MAXX, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 09-02-2009, 07:31 PM   #4 (permalink)
SS1156's Avatar
The more positive offset you go the further inward the wheel goes. I personally think -25 is too much for my taste, but that me.
FOR SALE:03 Patriot Blue CTD 2500 2wd QuadCab, 305/555HO, Airaid box, Autometer pillar gauges, FBD Heater Grid Delete, FBD 5" TB pipes, Boost Fooler, boost elbow and a Predator helping out the HP's, he351 turbo upgrade on the way...but more to come.
SS1156 is offline   Reply With Quote
Old 09-02-2009, 08:06 PM   #5 (permalink)
Sorry guys... 2001 QCSB with 4 inch lift springs (instead of spacers... not sure about all that... but that is what the guy says and it is level).. I am actually going to pick it up Friday I am getting it for the right price so I will have some play money right off the bat... and it needs new tires......
I want 35X12.50R20 Tires... Federal's.... with a 20 x 9....
So a +42 (like stokers) would be inset... -12 would be a little more out.?.?.?. then a -25 would be a little more out.?.?.?. and -51 is just get-r-done out right.?.?.?.
MrNiceGuy has the federal tires I plan to run....
His wheels a cool... just a little too out from the fender weal(not sure if I spelled that right).....
Old 09-02-2009, 08:09 PM   #6 (permalink)
New Mexico Chapter President
sofakingbad's Avatar
stay between +10 an -10 an you should be fine....
2010 CCSB 4x4 Laramie
Previous Cummins:
(2)05's,04,03,02,(2)01's,97,95,93 12v's. 11 total
forsale: 100% stock 03 qclb 4x4 auto. $16,800 obo
sofakingbad is online now   Reply With Quote
Old 09-02-2009, 08:20 PM   #7 (permalink)
See MrNiceGuy's wheels....
BMF Wheels: NOVAKANE 8 (Death Metal Black) - 20x9 8x6.5 +0
or...
BMF Wheels: NOVAKANE 8 (Death Metal Black) - 20x10 8x6.5 +-19
Not sure....
This is the wheel I want....
Ultra Wheels: Thunder (Gloss Black W/Diamond Cut) - 20x9 8x6.5 +18
Ultra Wheels: Thunder (Gloss Black W/Diamond Cut) - 20x10 8x6.5 +-25
Or these...
SIZE: 20" X 9"
BOLT PATTERN: 8 X 6.5", 8 LUG
OFFSET: -12MM
BACKSPACING 4.5"
Old 09-02-2009, 09:26 PM   #8 (permalink)
Jamie Johnson.... "Aaaa Pictuuure's worth a 1000 worrrdss"
PERFECT!!!
KMC XD ADDICT MATTE BLACK WHEEL
18x9's +18mm offsets.
Old 09-02-2009, 09:30 PM   #9 (permalink)
Scott183's Avatar
With that much of a lift and 35's any of the wheel/ tire combos you mentioned will work. It's more a matter of personal taste as far as how much you want them to stick out. A 4.5" backspaced wheel will leave approx. 3" of tire exposed. My personal taste is in the 5-5.5" backspace unless your jacked 8"+. JMO.
Old 09-03-2009, 10:28 AM   #10 (permalink)
jomac11's Avatar
PERFECT!!!
What size tires are those? My XD Badlands 20x9s and +18 will be here today or tomorrow...
08 Mineral Gray Metallic Quad Cab SB, CTD, Auto
20x9 KMC XD Badlands, Chrome, 325/50/20 Mickey Thompson ATZ
jomac11 is offline   Reply With Quote
Old 09-03-2009, 10:44 AM   #11 (permalink)
Scott183's Avatar
Looks like a 33? Just a guess.
