Old 07-20-2009, 07:11 PM   #1 (permalink)
22.5's 10r22.5
i can get a killer deal on a set of 10 22.5's with pretty new 10r22.5 tires on alcoa's
i think these tires are about 40 in tall would a 4in lift clear it???or would i have to go higher
ohh yeah i have a 06 3500 drw 4x4 with a 2 in space in the front
06 3500 drw hand shaker
dirtycj5 is offline   Reply With Quote
Old 07-22-2009, 07:25 PM   #2 (permalink)
bump any ideas?????????
Old 07-23-2009, 01:34 AM   #3 (permalink)
Performance's Avatar
Im pretty sure the 4" lift won't be enough. Whatever size lift the guys are using to clear 40"s on a single wheel, that's the size you will need too. It's going to have to be a pretty big lift just to clear though.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Classic Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
Old 07-23-2009, 01:38 AM   #4 (permalink)
SootKing's Avatar
i dont think youll be close with 40's...maybe with an 8 inch or 9 inch lift...
P-pumped 02 graphite,short bed,fass 95, KMC ambush 22's,100 horse sticks,icebox S&B, banks brake, NEW 215 p pump, 4gsk, laser cut dv's, 24 degree timing, street cam, DSS and solid steel 3rd gen trac bar, leveled, Fleece suncoast transmission, HID's, 8 in CAT stack
SootKing is offline   Reply With Quote
Old 07-23-2009, 03:02 AM   #5 (permalink)
Diesel Junkie
Rmarkey's Avatar
4.5 inch lift clears 37's all day, check out a 6" lift to fit your 40's.
'04½ w/ Juice/Attitude, AFE PG7 Stage 2, CFM+, FASS, Boost cooler stg3, Dual 7 inch miters, 48RE, 37" MTRs, Projectors w/HIDs, LED tails color matched
Rmarkey is offline   Reply With Quote
Old 07-23-2009, 08:26 AM   #6 (permalink)
performance........ what are you running to clear the 255/70 22.5's from what ive been seeing on line 255/70's are about 36-36.5 tall with a 2in spacer to clear on a 4x4.
Old 07-23-2009, 08:27 AM   #7 (permalink)
i with you i think 6in will be close to perfect maybe a tad on the high side
Old 07-26-2009, 03:15 PM   #8 (permalink)
Im just using a 2" leveling kit, but it's super close. I haven't had them to rub though. The 10r22.5s will rub in the front when turning for sure. That's why you don't see many people running that big of a tire size. The offset on the Alcoas just won't be enough to keep them from rubbing even if you have plenty of lift to clear them. The 10rs are wider than a 70 series tire which will cause a clearence problem with the rear leaf springs on the inner wheels on the rear. This also will add to the problem in the front. Most 70 series tires are as wide as you can run, without major suspension mods, spacers, custom adaptors, or something to get the wheels out.
I will say some 10rs may fit depending on the tire company, but it's something you will have to definitly check first before buying or it could be a bad deal. I have seen 9rs on a Dodge before.
Old 07-26-2009, 06:38 PM   #9 (permalink)
thanks performance im gonna be looking for 255/70 22.5's when i think about it i really dont want to daily drive a hight truck
Old 07-28-2009, 02:43 AM   #10 (permalink)
No problem. The 255/70 is really the best size for these trucks and especially for a daily driver. It's going to put the truck up around 3" higher anyway. The larger sizes in the commercial tires are also heavier and you will tell the difference even with the 255/70s. It's just much easier to use this size.
Old 07-28-2009, 02:55 AM   #11 (permalink)
First Timer
big94GMC's Avatar
I'm running a 3" Pro Comp lift to clear my 255/70x22.5's....very nice!!
......Chris
--'94 GMC Sierra 2wd, 5.7, NV3500, 3.73, 6" RCD, 33" ProComp, stereo
--'95 GMC Sonoma 4x4, 4.3, 4L60e, 203/205 trip stick, D60's, 4.10 welded, 38" SX's on H1's
--'04 Dodge Ram 4x4, 5.9, NV5600, 273, 3.73, 3" ProComp, 22.5 Aloca's, some goodies
big94GMC is offline   Reply With Quote
Old 07-28-2009, 09:46 AM   #12 (permalink)
hey bro got a pic of you truck?????
